跳转到主内容
Nikon Coolpix S210 LCD screen Replacement
Mallory Arend
Mallory Arend7 其他贡献者
最后更新于 July 18, 2020
没有估计
中等
特色指南
You will be removing the back casing of the camera. You will need a Phillips #00 screwdriver and a spudger. You will then be directed to remove screws.
你所需要的
工具
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Nikon Coolpix S210 LCD screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Place thumb on the battery cover panel on the bottom of the device.
    • Slide the panel to the right away from the camera.
  2. Nikon Coolpix S210 LCD screen Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix S210 LCD screen Replacement: 步骤 2 中的图像 2,2
    • Slide the orange latch outward towards the corner of the camera.
    • The battery should pop out.
    • Remove the battery and reattach the cover.
    Thank You!!! Amazing how easily I can complicate anything!! You are my hero. Retro picture taking ~ here I come!!
    Jennifer Curran - 回复
  3. Nikon Coolpix S210 LCD screen Replacement, Back Case: 步骤 3 中的图像 1,1
    • After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
  4. Nikon Coolpix S210 LCD screen Replacement: 步骤 4 中的图像 1,1
    • Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
  5. Nikon Coolpix S210 LCD screen Replacement: 步骤 5 中的图像 1,1
    • Unscrew the two 4.05mm screws on the side next to the buttons.
  6. Nikon Coolpix S210 LCD screen Replacement: 步骤 6 中的图像 1,2 Nikon Coolpix S210 LCD screen Replacement: 步骤 6 中的图像 2,2
    • Gently wedge the flat end of the spudger between the back case and the wrist-strap mount.
    • The wrist-strap mount is the thin metal piece on the side of the camera. Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
    • Carefully pry the back case away from the camera and then gently lift it off.
  7. Nikon Coolpix S210 LCD screen Replacement, LCD screen: 步骤 7 中的图像 1,3 Nikon Coolpix S210 LCD screen Replacement, LCD screen: 步骤 7 中的图像 2,3 Nikon Coolpix S210 LCD screen Replacement, LCD screen: 步骤 7 中的图像 3,3
    • Having removed the back case, the LCD screen should be sitting loosely on the camera, attached only by a wide ribbon and a narrow ribbon.
    • The ribbons are connected to and held in place by small plastic latches.
    • To remove the wide ribbon, gently pry the spudger underneath the black plastic latch where the ribbon connects and lift up. The ribbon should slide out easily.
    • Repeat the same process with the smaller ribbon, this time looking for a light blue latch.
  8. Nikon Coolpix S210 LCD screen Replacement: 步骤 8 中的图像 1,1
    • Gently remove the LCD screen.
结论
2等其他人完成本指南。
Mallory Arend
于01/17/11注册
474 声望
创作了2篇指南
团队
Cal Poly, Team 5-17, Amido Winter 2011 Cal Poly, Team 5-17, Amido Winter 2011 的会员
CPSU-AMIDO-W11S5G17
6 名成员
创作了12篇指南
一条评论
Funcionou conforme descrito! Funciona para a Nikon Coolpix S203
geral - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 25
总计 4,170
