跳转到主内容
Nikon Coolpix P90 Battery Replacement
Elizabeth Kamine
Elizabeth Kamine5 其他贡献者
最后更新于 July 2, 2024
1分钟
非常容易
Follow this guide to replace the battery of your Nikon Coolpix P90 camera with a fully charged EN-EL5 rechargeable Li-ion battery. It provides 3.7V and 1100mAh. Check your battery to ensure you are replacing with a compatible model.
Make sure that your camera is off and unplugged from the charger before you begin this repair.
  1. Nikon Coolpix P90 Battery Replacement, Camera Base: 步骤 1 中的图像 1,3 Nikon Coolpix P90 Battery Replacement, Camera Base: 步骤 1 中的图像 2,3 Nikon Coolpix P90 Battery Replacement, Camera Base: 步骤 1 中的图像 3,3
    • Use your finger to push the latch of the compartment door to the center of the camera body, per image 1.
    • Push the door open, and remove the existing battery with your fingers, per images 2-3.
结论
团队
Cal Poly, Team 20-14, Maness Winter 2015 Cal Poly, Team 20-14, Maness Winter 2015 的会员
CPSU-MANESS-W15S20G14
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,184
