跳转到主内容
Nikon Coolpix P510 LCD Replacement
Brian Hulsey
Brian Hulsey4 其他贡献者
最后更新于 July 10, 2020
2 - 5 分钟
简单
If you are having issues with your LCD, this guide will help you replace it with a minimal effort. This part is easy to get to, and easy to replace. Other than a screwdriver and a plastic opening tool, nothing else is needed to accomplish this.
你所需要的
工具
查看更多...
  1. Nikon Coolpix P510 LCD Replacement, Battery Removal: 步骤 1 中的图像 1,1
    • Flip the camera over and push the tab on the battery cover to open the battery compartment.
  2. Nikon Coolpix P510 LCD Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix P510 LCD Replacement: 步骤 2 中的图像 2,2
    • Push the little yellow tab to allow the battery to slide out.
    • With the tab pushed out, pull the battery out.
  3. Nikon Coolpix P510 LCD Replacement, LCD Screen Window: 步骤 3 中的图像 1,2 Nikon Coolpix P510 LCD Replacement, LCD Screen Window: 步骤 3 中的图像 2,2
    • Extend the LCD screen out and turn the camera upside down to get access to the screws on the bottom.
  4. Nikon Coolpix P510 LCD Replacement: 步骤 4 中的图像 1,2 Nikon Coolpix P510 LCD Replacement: 步骤 4 中的图像 2,2
    • Take the four 4mm PH00 Phillips screws out.
  5. Nikon Coolpix P510 LCD Replacement: 步骤 5 中的图像 1,2 Nikon Coolpix P510 LCD Replacement: 步骤 5 中的图像 2,2
    • Use a plastic opening tool to trace around the screen to pop the front and back section apart.
  6. Nikon Coolpix P510 LCD Replacement, LCD: 步骤 6 中的图像 1,2 Nikon Coolpix P510 LCD Replacement, LCD: 步骤 6 中的图像 2,2
    • Tilt the LCD up to get access to the back of it.
  7. Nikon Coolpix P510 LCD Replacement: 步骤 7 中的图像 1,2 Nikon Coolpix P510 LCD Replacement: 步骤 7 中的图像 2,2
    • Unplug the ribbon cables on the side of the chip under the LCD by simple pulling lightly on them.
  8. Nikon Coolpix P510 LCD Replacement: 步骤 8 中的图像 1,1
    • The chip has an adhesive on it to keep it attached to the LCD, and you will need to use a plastic opening tool to get it off.
    • It may take a little bit of pressure to get the chip off. Be gentle to make sure you don't break the chip.
结论
6等其他人完成本指南。
Brian Hulsey
于03/31/15注册
1,506 声望
创作了6篇指南
团队
Colorado Springs, Team 2-2, Panko Spring 2015 Colorado Springs, Team 2-2, Panko Spring 2015 的会员
UCCS-PANKO-S15S2G2
3 名成员
创作了12篇指南
2条评论
Esse LSD tem outro fita preta que conecta pode estar ruim
Leonardo Silva - 回复
Porque a minha não sei se ela é LCD ou esse negócio preto que conecta que tá ruim
Leonardo Silva - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 41
总计 6,029
