跳转到主内容
Nikon Coolpix L820 Shutter Button Replacement
Jimmy Kendall
Jimmy Kendall8 其他贡献者
最后更新于 January 10, 2025
10分钟
简单
需要更好的图片
The shutter is a very important part of the camera because without it you can't take pictures. This guide will give you the steps to access this button and replace this button.
你所需要的
工具
查看更多...
  1. Nikon Coolpix L820 Shutter Button Replacement, Settings Buttons: 步骤 1 中的图像 1,3 Nikon Coolpix L820 Shutter Button Replacement, Settings Buttons: 步骤 1 中的图像 2,3 Nikon Coolpix L820 Shutter Button Replacement, Settings Buttons: 步骤 1 中的图像 3,3
    • Remove the battery before beginning.
    • Use a Phillips #0 screwdriver to remove the screws on the front casing. There are 10 screws around the casing. 3 are located on the left side of the camera, 6 are located on the bottom near the product label, and 1 is located on the right side of the camera.
  2. Nikon Coolpix L820 Shutter Button Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix L820 Shutter Button Replacement: 步骤 2 中的图像 2,2
    • Next, remove the screw held on top of the camera above the Nikon logo.
    • Moving to the bottom of the camera, open the empty battery slot, and locate the 4 screws in the compartment. Begin removing the 4 screws located within.
  3. Nikon Coolpix L820 Shutter Button Replacement: 步骤 3 中的图像 1,3 Nikon Coolpix L820 Shutter Button Replacement: 步骤 3 中的图像 2,3 Nikon Coolpix L820 Shutter Button Replacement: 步骤 3 中的图像 3,3
    • Using the spudger, begin prying the case from the device, carefully separating the rear housing from the camera assembly. Once the rear housing is separated, the camera's physical buttons will be accessible for replacement.
    • Be sure to only apply pressure to the casing panels, not internal electronics. Doing so can damage the internal components of the camera.
  4. Nikon Coolpix L820 Shutter Button Replacement, LCD screen: 步骤 4 中的图像 1,3 Nikon Coolpix L820 Shutter Button Replacement, LCD screen: 步骤 4 中的图像 2,3 Nikon Coolpix L820 Shutter Button Replacement, LCD screen: 步骤 4 中的图像 3,3
    • Remove the front casing around the LCD screen from the camera.
    • Avoid putting pressure or moving the exposed wires. This can damage them and cause lasting issue to the camera.
  5. Nikon Coolpix L820 Shutter Button Replacement: 步骤 5 中的图像 1,3 Nikon Coolpix L820 Shutter Button Replacement: 步骤 5 中的图像 2,3 Nikon Coolpix L820 Shutter Button Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    • Using the tweezers shown in the materials list, lift the hinges connecting the two ribbon wires to the camera. The wires will unlatch from the device.
  6. Nikon Coolpix L820 Shutter Button Replacement: 步骤 6 中的图像 1,2 Nikon Coolpix L820 Shutter Button Replacement: 步骤 6 中的图像 2,2
    • Once the ribbon wires are disconnected, remove the LCD screen from the camera.
    • Safely store the LCD for reinstallation.
  7. Nikon Coolpix L820 Shutter Button Replacement, Shutter Button: 步骤 7 中的图像 1,1
    • Remove the five screws from the back of the camera using a Phillips #0 screwdriver.
  8. Nikon Coolpix L820 Shutter Button Replacement: 步骤 8 中的图像 1,1
    • Using the pointed edge of the spudger, remove the hinge that secure's the camera's flex circuit. This will unfasten the camera's ribbon wire.
  9. Nikon Coolpix L820 Shutter Button Replacement: 步骤 9 中的图像 1,1
    • Remove the shutter's plastic cover from the camera by lifting the piece up. It will disconnect from the device.
  10. Nikon Coolpix L820 Shutter Button Replacement: 步骤 10 中的图像 1,1
    在这个步骤中使用的工具:
    • Remove the metal cover using tweezers to allow access to the shutter button. Take the new shutter button and place it where the original piece was located.
结论
2等其他人完成本指南。
Jimmy Kendall
于03/23/15注册
137 声望
撰写一个指南
团队
UMass Dartmouth, Team 1-4, Miles Spring 2015 UMass Dartmouth, Team 1-4, Miles Spring 2015 的会员
UMASSD-MILES-S15S1G4
3 名成员
创作了10篇指南
3指南评论
Muy bueno pero falta documentar 3 tornillos.
1. En el paso 1, en la tercera foto debajo del sticker del código de barras.
2. En el paso 2, justo en el fondo del compartimento de una de las baterías (la del extremo). Incluso se alcanza a apreciar en la foto.
3. En el paso 8, en esa misma pieza de metal a un lado está el otro tornillo.
cyrez_1509 - 回复
My shutter button still works but doesn’t give feedback. It’s hard to tell when I’ve taken a picture because it doesn’t “click.” I’m wondering if that’s something that can be fixed, but I can’t tell if the mechanism for that feedback is in the mechanical portion above (and maybe a piece of metal broke) or built into the switch soldered on the circuit board.
JM Palacios - 回复
Dove si può acquistare il bottone a buon prezzo? grazie
Where can you buy the button at a good price? Thank you
Massimino Diquarto - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 3,471
