跳转到主内容
Nikon Coolpix L340 Buttons Replacement
Robert Estrella
Robert Estrella2 其他贡献者
最后更新于 June 28, 2020
5分钟
简单
This guide is meant to help the user replace the buttons on the back of the camera after they remove the back panel. This could be to fix a jammed button or simply replace the part as you wish. The only required tool for this process would be a 5mm Phillips Head number #000 screwdriver.
你所需要的
工具
  1. Nikon Coolpix L340 Buttons Replacement, Buttons: 步骤 1 中的图像 1,1
    • Remove the 5 mm Phillips #000 screw located on the upper left side of the camera
    • Remove the 5 mm Phillips #000 screw located on the lower left side of the camera
  2. Nikon Coolpix L340 Buttons Replacement: 步骤 2 中的图像 1,1
    • Remove the 5 mm Phillips #000 screw from the upper right side of the camera.
    • Remove the 5 mm Phillips #000 screw from the lower right side of the camera.
  3. Nikon Coolpix L340 Buttons Replacement: 步骤 3 中的图像 1,1
    • Remove the 5 mm Phillips #000 screw from the bottom left of the camera.
    • Remove the 5 mm Phillips #000 screw from the left-center of the bottom of the camera.
    • Remove the 5 mm Phillips #000 screw from the center of the bottom of the camera.
  4. Nikon Coolpix L340 Buttons Replacement: 步骤 4 中的图像 1,1
    • Remove back cover of the camera.
  5. Nikon Coolpix L340 Buttons Replacement: 步骤 5 中的图像 1,1
    • Push buttons out of the back of the cover.
结论
Robert Estrella
于03/04/16注册
101 声望
撰写一个指南
团队
UMass Dartmouth, Team 3-3, Bhusal Spring 2016 UMass Dartmouth, Team 3-3, Bhusal Spring 2016 的会员
UMASSD-BHUSAL-S16S3G3
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 25
总计 1,326
