跳转到主内容
Nikon Coolpix L340 Battery Replacement
Nikki Butts
Nikki Butts2 其他贡献者
最后更新于 June 29, 2020
5分钟
简单
The batteries in your camera only last a certain amount of time before they die and it is time to replace them. Once this happens, the camera will not be able to turn on until all four of the batteries are replaced. The batteries used in this camera are AA batteries.
  1. Nikon Coolpix L340 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Nikon Coolpix L340 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the camera so that the flash is facing downward- you are now looking at the bottom of the camera
    • If the camera lens its pointing towards you, there should be a small lever on the right hand side
    • Take this lever and push it away from your body, while simultaneously pulling upwards
  2. Nikon Coolpix L340 Battery Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix L340 Battery Replacement: 步骤 2 中的图像 2,2
    • Once you have pulled up, four batteries will appear underneith
    • Note how there are two batteries facing upwards (circled in red)
    • and two batteries facing downwards (circled in orange)
    • When the new batteries are placed back in the camera, they should be put back in this same orientation
  3. Nikon Coolpix L340 Battery Replacement: 步骤 3 中的图像 1,1
    • Take out each of the batteries
  4. Nikon Coolpix L340 Battery Replacement: 步骤 4 中的图像 1,1
    • When all of the batteries have been removed you should see four places for four new batteries to be inserted
结论
2等其他人完成本指南。
Nikki Butts
于03/04/16注册
179 声望
撰写一个指南
团队
UMass Dartmouth, Team 3-3, Bhusal Spring 2016 UMass Dartmouth, Team 3-3, Bhusal Spring 2016 的会员
UMASSD-BHUSAL-S16S3G3
4 名成员
创作了8篇指南
4条评论
Hi, I just replaced my Nikon Coolpix L340's batteries with new AAs and have followed all steps correctly but my camera is still saying 'battery exhausted' when I try turning it back on. Any ideas why it's not working?
Thank you!
Mia - 回复
The negative terminal must be raised like the Duracell Ultra. The Energizer MAX and other AAs have a FLAT negative terminal. The manual warns against them.
thestevelink -
No lever, only recessed button
ccpotts47 - 回复
thestevelink - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 28
过去 30 天: 99
总计 10,638
