跳转到主内容
Nikon Coolpix L320 Battery Replacement
MollyHenderson
MollyHenderson3 其他贡献者
最后更新于 June 28, 2024
1 - 5 分钟
简单
If you notice that your Nikon Coolpix L320 camera is failing to power on, it may be due to the camera’s batteries being dead. Batteries provide the electrical power necessary for the camera to turn on and operate. However, dead batteries will not give the power necessary to perform this function. Replacing the batteries will help your camera to function once again.
This quick guide will walk you through the process of replacing your camera’s old batteries with a new set. Before you begin, make sure your camera is completely turned off. The batteries may be hot immediately after using the camera so practice caution when removing them. Also, make sure to only use one type of battery for all four slots as mixing and matching may cause the camera to not turn on. Let's get started!
  1. Nikon Coolpix L320 Battery Replacement, Batteries: 步骤 1 中的图像 1,2 Nikon Coolpix L320 Battery Replacement, Batteries: 步骤 1 中的图像 2,2
    • Flip the camera over to reveal the card/battery door.
    • Slide the button to the unlocked position and the door should pop open.
  2. Nikon Coolpix L320 Battery Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix L320 Battery Replacement: 步骤 2 中的图像 2,2
    • Take out the old batteries.
    • Look at the yellow sticker inside of the the battery compartment. You'll see the symbol for the direction the new battery should face when replaced.
    • The “+” means to put the raised end facing up. The “-“ means to put the flat end up.
结论
MollyHenderson
于03/20/23注册
293 声望
创作了2篇指南
团队
UMass Dartmouth, Team 5-6, Ramos Spring 2023 UMass Dartmouth, Team 5-6, Ramos Spring 2023 的会员
UMASSD-RAMOS-S23S5G6
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 42
总计 623
