跳转到主内容
Nikon Coolpix L32 Memory Card Replacement
Weston Phillips
Weston Phillips3 其他贡献者
最后更新于 June 26, 2020
15 - 30 秒
非常容易
The guide will show how to properly replace a memory card from the Nikon Coolpix L32 camera.
  1. Nikon Coolpix L32 Memory Card Replacement, Memory Card: 步骤 1 中的图像 1,1
    • Slide the lock button on the battery compartment away from you while sliding the battery compartment door to the right to open the battery compartment door.
  2. Nikon Coolpix L32 Memory Card Replacement: 步骤 2 中的图像 1,1
    • Push in the memory card until you hear a “click” noise, remove the old one and install the new one
    • When the new memory card is being installed make sure to hear a "click" noise once again
结论
Weston Phillips
于09/20/16注册
104 声望
撰写一个指南
团队
USF Tampa, Team 2-4, Blackwell Fall 2016 USF Tampa, Team 2-4, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S2G4
4 名成员
创作了10篇指南
1指南评论
Very informative
Simon Munoz - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 24
总计 710
