跳转到主内容
Nikon Coolpix L27 Screen Replacement
Vishalpreet Sandhu
Vishalpreet Sandhu 另一个贡献者
最后更新于 May 4, 2022
20 - 40 分钟
中等
If your Nikon COOLPIX L27 screen does not turn on or is damaged, you can use this guide to replace the screen.
The screen is a vital part of the camera, it shows a preview of images and allows easy access to them. A faulty or damaged screen greatly hinders the usability of the camera. A simple repair such as this can extend the life of the camera to be used again or repurposed.
Before starting the repair, test your camera to see if it still turns on with a new pair of batteries to make sure that the screen is the only fix needed.
你所需要的
工具
  1. Nikon Coolpix L27 Screen Replacement, Screen: 步骤 1 中的图像 1,3 Nikon Coolpix L27 Screen Replacement, Screen: 步骤 1 中的图像 2,3 Nikon Coolpix L27 Screen Replacement, Screen: 步骤 1 中的图像 3,3
    • Undo the latch at the bottom of the camera by pushing it to the side
    • Remove the batteries (and memory card if applicable)
  2. Nikon Coolpix L27 Screen Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix L27 Screen Replacement: 步骤 2 中的图像 2,2
    • Remove the two 5 mm Phillips #000 screws from the left side.
  3. Nikon Coolpix L27 Screen Replacement: 步骤 3 中的图像 1,3 Nikon Coolpix L27 Screen Replacement: 步骤 3 中的图像 2,3 Nikon Coolpix L27 Screen Replacement: 步骤 3 中的图像 3,3
    • Lift the cover labeled "A/V OUT" to expose a hidden screw.
    • Remove two 5 mm Phillips #000 screws from the bottom of the camera.
  4. Nikon Coolpix L27 Screen Replacement: 步骤 4 中的图像 1,2 Nikon Coolpix L27 Screen Replacement: 步骤 4 中的图像 2,2
    • Remove the two 5 mm Phillips #000 screws from the right side of the camera.
  5. Nikon Coolpix L27 Screen Replacement: 步骤 5 中的图像 1,3 Nikon Coolpix L27 Screen Replacement: 步骤 5 中的图像 2,3 Nikon Coolpix L27 Screen Replacement: 步骤 5 中的图像 3,3
    • Carefully pry the back cover starting from the battery latch.
    • Once all sides are loose, lift the back cover up and off.
  6. Nikon Coolpix L27 Screen Replacement: 步骤 6 中的图像 1,1
    • Carefully lift the LCD screen up towards the bottom of the camera.
    • The LCD is connected to a cable so don't pull it out yet.
  7. Nikon Coolpix L27 Screen Replacement: 步骤 7 中的图像 1,1
    • Lightly push back the white switch holding in the screen cable
  8. Nikon Coolpix L27 Screen Replacement: 步骤 8 中的图像 1,2 Nikon Coolpix L27 Screen Replacement: 步骤 8 中的图像 2,2
    • Remove the cable from the camera.
    • Lift the screen out.
结论
Vishalpreet Sandhu
于01/18/22注册
157 声望
撰写一个指南
团队
2条评论
would you know how to replace the little button battery just next to the screen, because the Lense is not retracting anymore?
Walter D. - 回复
where can i buy a screen replacement please
mo0nflwr - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 29
总计 943
