跳转到主内容
加入维修社区 - 创建账户
Nikon Coolpix 3500 Lens Replacement
你所需要的
    1. Nikon Coolpix 3500 Lens Replacement, Battery: 步骤 1 中的图像 1,1
      • Unlatch the battery cover and slide the cover out. Place cover to the side, it will not be needed for the next few steps.
      • Remove the battery.
      • Remove the battery cover without using excessive force. Keep in mind this cover is fragile.
      询问修复机器人
      添加评论
    1. Nikon Coolpix 3500 Lens Replacement, Front Cover: 步骤 2 中的图像 1,1
      • Remove the two 4.5 mm screws that sit next to the battery slot.
      • Remove the 3 mm screw that sits below the CF card slot.
      • Remove the 4.5 mm screw that sits above the digital I/O cover.
      询问修复机器人
      添加评论
    2. Nikon Coolpix 3500 Lens Replacement: 步骤 3 中的图像 1,1
      • Remove the two 4.5 mm screws that sit inside the battery slot.
      询问修复机器人
      添加评论
    3. Nikon Coolpix 3500 Lens Replacement: 步骤 4 中的图像 1,1
      • Remove the two 5 mm screws that sit near the camera strap eyelet.
      • Remove the camera strap eyelet.
      询问修复机器人
      添加评论
    4. Nikon Coolpix 3500 Lens Replacement: 步骤 5 中的图像 1,1
      • Remove the 5 mm screw and cap that were underneath the camera strap eyelet.
      询问修复机器人
      添加评论
    5. Nikon Coolpix 3500 Lens Replacement: 步骤 6 中的图像 1,2 Nikon Coolpix 3500 Lens Replacement: 步骤 6 中的图像 2,2
      • Remove the five 3.5 mm screws that sit at the bottom of the camera.
      • Remove the grey plastic piece, which the five screws held in place, by gently detaching the front cover.
      • Do not apply too much force; two wires still connect the front cover to the motherboard.
      询问修复机器人
      添加评论
    6. Nikon Coolpix 3500 Lens Replacement: 步骤 7 中的图像 1,2 Nikon Coolpix 3500 Lens Replacement: 步骤 7 中的图像 2,2
      • Using a spudger, detach the white-capped wire.
      • Using a spudger, detach the orange-capped wire and set the front cover aside.
      询问修复机器人
      添加评论
    1. Nikon Coolpix 3500 Lens Replacement, Lens: 步骤 8 中的图像 1,1
      • Disconnect the grey-capped wire from the motherboard.
      • Disconnect the blue wire attached to the green chip from the center of the motherboard.
      询问修复机器人
      添加评论
    2. Nikon Coolpix 3500 Lens Replacement: 步骤 9 中的图像 1,2 Nikon Coolpix 3500 Lens Replacement: 步骤 9 中的图像 2,2
      • Remove the 3.5 mm screw from the motherboard next to the rotating lens.
      • Invert the motherboard and lens toward the orange and blue wires still connecting the motherboard to the LED screen.
      询问修复机器人
      添加评论
    3. Nikon Coolpix 3500 Lens Replacement: 步骤 10 中的图像 1,2 Nikon Coolpix 3500 Lens Replacement: 步骤 10 中的图像 2,2
      • Disconnect the blue wire connecting the motherboard to the LED screen.
      • Disconnect the orange wire using a spudger while pushing out horizontally.
      • Disconnect the red capped wire from the motherboard.
      • Lift the motherboard and lens (still connected) out of the back case.
      询问修复机器人
      添加评论
    4. Nikon Coolpix 3500 Lens Replacement: 步骤 11 中的图像 1,1
      • Lift up on the black covering and remove the orange wire connecting the lens to the motherboard.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team 30-38, Garner Spring 2010 Cal Poly, Team 30-38, Garner Spring 2010 的会员
CPSU-GARNER-S10S30G38
5 名成员
创作了17篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 37
总计 3,528
