跳转到主内容
Nikon COOLPIX S610c Rear Casing Replacement
Kevin Backers
Kevin Backers5 其他贡献者
最后更新于 August 4, 2020
30分钟
中等
动态照片拍摄
步骤精简
If your rear casing needs to be replaced, if it's been cracked for example, follow this guide to remove the current rear case. In this guide ZxY denotes a screw with Z-length and Y-width.
你所需要的
工具
  1. Nikon COOLPIX S610c Rear Casing Replacement, Battery: 步骤 1 中的图像 1,1
    • On the bottom right of the camera, locate the battery flap switch.
  2. Nikon COOLPIX S610c Rear Casing Replacement: 步骤 2 中的图像 1,1
    • Move this switch to the right so the battery flap can flip open.
  3. Nikon COOLPIX S610c Rear Casing Replacement: 步骤 3 中的图像 1,1
    • Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
  4. Nikon COOLPIX S610c Rear Casing Replacement, Rear Casing: 步骤 4 中的图像 1,1
    • Remove the three 3x3mm screws attached to the rear casing.
  5. Nikon COOLPIX S610c Rear Casing Replacement: 步骤 5 中的图像 1,1
    • The panel can be identified by the wifi logo on its upper half on the camera's side.
    • Remove the 5x3mm screw holding down the panel on the side closest to the lens.
  6. Nikon COOLPIX S610c Rear Casing Replacement: 步骤 6 中的图像 1,1
    • Pry the panel off from the bottom using your fingernail.
  7. Nikon COOLPIX S610c Rear Casing Replacement: 步骤 7 中的图像 1,1
    • Remove the 3x2mm screw underneath the panel near the top of the camera.
  8. Nikon COOLPIX S610c Rear Casing Replacement: 步骤 8 中的图像 1,2 Nikon COOLPIX S610c Rear Casing Replacement: 步骤 8 中的图像 2,2
    • Remove the 4x3mm on the opposite side near the selector wheel.
    • Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
  9. Nikon COOLPIX S610c Rear Casing Replacement: 步骤 9 中的图像 1,2 Nikon COOLPIX S610c Rear Casing Replacement: 步骤 9 中的图像 2,2
    • Pry the back panel away from the body of the camera, using the space you just opened up.
    • Be careful not to damage the ribbon cable on the opposite end of the camera.
    • A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
  10. Nikon COOLPIX S610c Rear Casing Replacement: 步骤 10 中的图像 1,2 Nikon COOLPIX S610c Rear Casing Replacement: 步骤 10 中的图像 2,2
    • Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
    • The center connector is detached by flipping the black latch up and away from the center of the camera.
    • The smaller connector is detached by flipping the tan latch up and away from the edge of the camera.
结论
另外一个人完成了本指南。
Kevin Backers
于01/26/12注册
301 声望
创作了4篇指南
团队
Cal Poly, Team 9-5, Regan Winter 2012 Cal Poly, Team 9-5, Regan Winter 2012 的会员
CPSU-REGAN-W12S9G5
5 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 912
