跳转到主内容
Nikon COOLPIX S3600 Battery Cover Replacement
Kim Maxson
Kim Maxson3 其他贡献者
最后更新于 July 26, 2020
5分钟
简单
This guide will detail the steps necessary to remove the battery cover from the camera.
你所需要的
工具
  1. Nikon COOLPIX S3600 Battery Cover Replacement, Battery Cover: 步骤 1 中的图像 1,2 Nikon COOLPIX S3600 Battery Cover Replacement, Battery Cover: 步骤 1 中的图像 2,2
    • Locate the battery cover on the right side of the bottom of the camera.
    • To open the cover, gently slide it in the direction indicated by the arrow.
  2. Nikon COOLPIX S3600 Battery Cover Replacement: 步骤 2 中的图像 1,3 Nikon COOLPIX S3600 Battery Cover Replacement: 步骤 2 中的图像 2,3 Nikon COOLPIX S3600 Battery Cover Replacement: 步骤 2 中的图像 3,3
    • Once the battery cover door is open, insert the pointed end of a spudger underneath the metal door hinge.
    • Gently twist the spudger; the battery door cover should pop off.
    • Completely remove the cover from the hinge.
结论
To reattach the battery cover door, align the metal hinge with the plastic cover and press the plastic cover downward until it snaps into place.
Kim Maxson
于03/18/15注册
101 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 453
