跳转到主内容
Nikon COOLPIX P2 WiFi Card Replacement
Joshua Avery
Joshua Avery5 其他贡献者
最后更新于 July 7, 2020
30分钟
中等
动态照片拍摄
你所需要的
工具
查看更多...
  1. Nikon COOLPIX P2 WiFi Card Replacement, Case: 步骤 1 中的图像 1,1
    • Remove the screw located near the speaker port using a Phillips 00 screwdriver.
  2. Nikon COOLPIX P2 WiFi Card Replacement: 步骤 2 中的图像 1,1
    • Turn camera upside down so that the battery compartment is facing you.
    • Remove all four screws from the bottom of the camera with a Phillips 00 screwdriver.
  3. Nikon COOLPIX P2 WiFi Card Replacement: 步骤 3 中的图像 1,1
    • Rotate the camera to the opposite side where the A/V outlet is located.
    • Unscrew and remove all four screws with a Phillips 00 screwdriver.
  4. Nikon COOLPIX P2 WiFi Card Replacement: 步骤 4 中的图像 1,1
    • Turn the camera so that the Wi-Fi adapter is facing you.
  5. Nikon COOLPIX P2 WiFi Card Replacement: 步骤 5 中的图像 1,3 Nikon COOLPIX P2 WiFi Card Replacement: 步骤 5 中的图像 2,3 Nikon COOLPIX P2 WiFi Card Replacement: 步骤 5 中的图像 3,3
    • Using a plastic opening tool, pry the front casing of the camera.
    • Continue this motion all around the front casing of the camera.
    • Gently pull apart the front casing from the rest of the camera.
  6. Nikon COOLPIX P2 WiFi Card Replacement: 步骤 6 中的图像 1,1
    • Using the plastic opening tool pry the back casing of the camera.
  7. Nikon COOLPIX P2 WiFi Card Replacement: 步骤 7 中的图像 1,1
    • Orange ribbon is fragile
    • Carefully pull apart the back casing of the camera from the front of the camera without tearing the orange ribbon.
  8. Nikon COOLPIX P2 WiFi Card Replacement: 步骤 8 中的图像 1,2 Nikon COOLPIX P2 WiFi Card Replacement: 步骤 8 中的图像 2,2
    • Pull down the on the black latch to carefully separate the orange ribbon from the motherboard.
    • Pull apart the orange ribbon and front casing from the rest of the camera.
  9. Nikon COOLPIX P2 WiFi Card Replacement, LCD Screen: 步骤 9 中的图像 1,2 Nikon COOLPIX P2 WiFi Card Replacement, LCD Screen: 步骤 9 中的图像 2,2
    • Use plastic opening tool to carefully pry the LCD Screen from the camera.
  10. Nikon COOLPIX P2 WiFi Card Replacement: 步骤 10 中的图像 1,2 Nikon COOLPIX P2 WiFi Card Replacement: 步骤 10 中的图像 2,2
    • Gently pull the ribbon cable down to release the latch, then pull up to remove it from the motherboard.
  11. Nikon COOLPIX P2 WiFi Card Replacement: 步骤 11 中的图像 1,1
  12. Nikon COOLPIX P2 WiFi Card Replacement, WiFi Card: 步骤 12 中的图像 1,1
    • Continue by removing two screws from the back of the camera body.
  13. Nikon COOLPIX P2 WiFi Card Replacement: 步骤 13 中的图像 1,1
    • Remove the screw connecting the wifi card cover to the front of the camera.
  14. Nikon COOLPIX P2 WiFi Card Replacement: 步骤 14 中的图像 1,1
    • Remove the final screw connecting the Wifi card cover to the case.
  15. Nikon COOLPIX P2 WiFi Card Replacement: 步骤 15 中的图像 1,1
    • Gently pull the Wifi card cover off of the camera body.
  16. Nikon COOLPIX P2 WiFi Card Replacement: 步骤 16 中的图像 1,1
    • Remove the screw holding the Wifi Card to the camera body.
  17. Nikon COOLPIX P2 WiFi Card Replacement: 步骤 17 中的图像 1,1
    • Gently pull the WiFi card out of the camera.
结论
2等其他人完成本指南。
Joshua Avery
于01/23/12注册
31 声望
创作了3篇指南
团队
Cal Poly, Team 3-28, Amido Winter 2012 Cal Poly, Team 3-28, Amido Winter 2012 的会员
CPSU-AMIDO-W12S3G28
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 911
