跳转到主内容
加入维修社区 - 创建账户
Nexus 7 2nd Generation Motherboard Replacement
你所需要的
    1. Nexus 7 2nd Generation Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,2 Nexus 7 2nd Generation Motherboard Replacement, Back Cover: 步骤 1 中的图像 2,2
      • Power down your device.
      • Use your plastic opening tool to wedge between the seams around the sides of the device. Pry open each side, one at a time. For some a finger nail may be best. The case comes up quite high to the glass.
      • Do not pry near the USB port at the base of the device as you may crack the rear panel.
      添加评论
    2. Nexus 7 2nd Generation Motherboard Replacement: 步骤 2 中的图像 1,1
      • Work fingers around the seam between device and back cover. Use your plastic opening tool and fingers to separate each side until device and back cover are completely apart.
      • Be careful around the corners. The body of the device can be fragile.
      添加评论
    1. Nexus 7 2nd Generation Motherboard Replacement, Battery: 步骤 3 中的图像 1,1
      • Insert the plastic opening tool under the side edge of the battery connector, and gently pry upward to disconnect it.
      添加评论
    2. Nexus 7 2nd Generation Motherboard Replacement: 步骤 4 中的图像 1,3 Nexus 7 2nd Generation Motherboard Replacement: 步骤 4 中的图像 2,3 Nexus 7 2nd Generation Motherboard Replacement: 步骤 4 中的图像 3,3
      • Use the flat end of a spudger or your fingernail to flip up the clear protective flap on the ribbon cable ZIF socket.
      • Using the flat end of a spudger or your fingernail, flip up the thin portion of the connector (the white part, opposite of the side where the cable inserts) to release the cable from its socket.
      • DO NOT PRY the socket on the side where the cable inserts, or you may break the entire socket off the motherboard.
      • Slide the cable out of the ZIF socket.
      • For more info on how to disconnect ZIF connectors, check out the Recognizing & Disconnecting Cable Connectors guide.
      添加评论
    3. Nexus 7 2nd Generation Motherboard Replacement: 步骤 5 中的图像 1,1
      • Peel protective foil cover back top of mother board to expose orange ribbon connection.
      • The ribbon connections should now be fully visible, with the plastic tabs exposed.
      询问修复机器人
      添加评论
    4. Nexus 7 2nd Generation Motherboard Replacement: 步骤 6 中的图像 1,3 Nexus 7 2nd Generation Motherboard Replacement: 步骤 6 中的图像 2,3 Nexus 7 2nd Generation Motherboard Replacement: 步骤 6 中的图像 3,3
      在这个步骤中使用的工具:
      • Using the tweezers, peel back the silver protective foil on top of the orange ribbon connector.
      • Using the plastic opening tool, pry upward under the orange ribbon connector. It will pop right out of place.
      询问修复机器人
      添加评论
    5. Nexus 7 2nd Generation Motherboard Replacement: 步骤 7 中的图像 1,2 Nexus 7 2nd Generation Motherboard Replacement: 步骤 7 中的图像 2,2
      • Now that the two main ribbons are disconnected, fold and hold them back with your fingers, or place the tweezers or a light object on the ribbons to keep them in place.
      添加评论
    6. Nexus 7 2nd Generation Motherboard Replacement: 步骤 8 中的图像 1,1
      • Use the #0 Phillips Screwdriver to remove the four silver 3 mm Philips #0 screws from around the battery housing.
      添加评论
    7. Nexus 7 2nd Generation Motherboard Replacement: 步骤 9 中的图像 1,1
      • Remove the battery from your device by applying pressure at the base of the battery and lifting it out.
      添加评论
    1. Nexus 7 2nd Generation Motherboard Replacement, Micro USB/Daughterboard: 步骤 10 中的图像 1,2 Nexus 7 2nd Generation Motherboard Replacement, Micro USB/Daughterboard: 步骤 10 中的图像 2,2
      • Remove the gray seal covering the top center screw on the daughterboard.
      • Be aware that this action will void your warranty.
      • Be sure to store the seal in a place where it will not get dirty and can retain its stickiness.
      添加评论
    2. Nexus 7 2nd Generation Motherboard Replacement: 步骤 11 中的图像 1,1
      • Using the Phillips #0 screwdriver, unscrew the 5 black 2 mm sized screws from around the edge of the daughterboard.
      • Use the same Phillips #0 screwdriver to remove the two silver 3 mm sized screws from either side of the micro USB.
      添加评论
    3. Nexus 7 2nd Generation Motherboard Replacement: 步骤 12 中的图像 1,2 Nexus 7 2nd Generation Motherboard Replacement: 步骤 12 中的图像 2,2
      在这个步骤中使用的工具:
      • Use the tweezers to unplug the speaker connector from the daughterboard by pulling sideways.
      • Be gentle in this step as this connector can be fragile. Do not pull upwards.
      询问修复机器人
      添加评论
    4. Nexus 7 2nd Generation Motherboard Replacement: 步骤 13 中的图像 1,1
      • Slowly peel off the EMI gasket over the ribbon cable assembly. This will expose the ribbon cable which can be removed from the connectors.
      询问修复机器人
      添加评论
    5. Nexus 7 2nd Generation Motherboard Replacement: 步骤 14 中的图像 1,2 Nexus 7 2nd Generation Motherboard Replacement: 步骤 14 中的图像 2,2
      • Use the flat end of a spudger or your fingernail to carefully flip up both retaining flaps one each of the ZIF sockets.
      • When disconnecting the ZIF sockets flip them outwards to the edge of the board/towards the cables respectively.
      • Be careful not to damage the pin connector. Pull parallel to the device, not up.
      添加评论
    6. Nexus 7 2nd Generation Motherboard Replacement: 步骤 15 中的图像 1,1
      • The daughterboard will now lift easily up and out of the device.
      • Use care during reassembly. This daughter board is a very sensitive part. It is easy to fry the digitizer part of this board if connections are made in the wrong order. Complete all other cable connections before connecting battery power.
      询问修复机器人
      添加评论
    1. Nexus 7 2nd Generation Motherboard Replacement, Motherboard: 步骤 16 中的图像 1,1
      在这个步骤中使用的工具:
      • Use the tweezers to peel the seal sticker off of the center screw that is closest to the battery.
      • Make sure to store the seal in a place where it will not get dirty and will retain its stickiness.
      添加评论
    2. Nexus 7 2nd Generation Motherboard Replacement: 步骤 17 中的图像 1,1
      • Using the tweezers, or carefully with your fingers, disconnect the speaker from its motherboard connection by pulling directly sideways.
      • Do not pull upwards. Doing so may warp or damage the connector.
      询问修复机器人
      添加评论
    3. Nexus 7 2nd Generation Motherboard Replacement: 步骤 18 中的图像 1,1
      添加评论
    4. Nexus 7 2nd Generation Motherboard Replacement: 步骤 19 中的图像 1,1
      • Using the #0 Philips head screwdriver, remove the three black 2 mm screws holding the inner edge of the motherboard in place.
      • Using the #0 Philips head screwdriver, remove the five silver 3 mm screws holding the outer edge of the motherboard in place.
      添加评论
    5. Nexus 7 2nd Generation Motherboard Replacement: 步骤 20 中的图像 1,3 Nexus 7 2nd Generation Motherboard Replacement: 步骤 20 中的图像 2,3 Nexus 7 2nd Generation Motherboard Replacement: 步骤 20 中的图像 3,3
      • Carefully lift the motherboard up from its edge and remove it from the tablet casing.
      • While the camera is connected directly to the motherboard from the bottom and might lift out of the tablet with the motherboard, it also might not. In this case, as shown, you'll need to use the tweezers to pry the camera out of its spot.
      • Removing the motherboard will reveal the top speaker that was being held down. If you are planning on replacing the top speaker, you may now simply pick it up out of the device.
      添加评论
结论
取消:我没有完成这个指南。
34等其他人完成本指南。
Alex Greene
于01/22/15注册
1,268 声望
撰写一个指南
团队
Cal Poly, Team 20-16, Maness Winter 2015 Cal Poly, Team 20-16, Maness Winter 2015 的会员
CPSU-MANESS-W15S20G16
4 名成员
创作了26篇指南
15指南评论
Very great guide on the teardown for swapping the motherboard. I have 2 questions if you wouldn't mind clearing up.
1. When you remove the back cover from the screen, is it glued into place or does it use small snaps to hold onto the device? How hard is it to reattach the back cover?
2. After buying a new motherboard for installation will I need to flash it with bios/firmware/OS to get it working or will it come as a ready-to-go motherboard?
Thanks for your help!
Robert Lewis - 回复 分享
Great guide, excellent pictures, helped me resurrect my Nexus stuck on the Google screen. Thank you!
However, it should be emphasized that steps 10-15 are completely unnecessary and should be skipped if you are only looking to replace the motherboard.
Ungha Bungha - 回复 分享
Agree on skipping steps 10-15 for motherboard replacement. The daughterboard was not in the way at all.
pacmanmaster - 回复 分享
Great guide and good instructions. I was able to swap out a faulty motherboard without any problems.
Two things I found that might need some addition/update on the instructions;
1) I found a #00 Phillips easier to use than the recommended #0 Phillips
2) You should probably add one more step to explain how the camera is attached with a ZIP socket to the underside of the motherboard. That would help in reconstructing the tablet in case, like me, your camera does not come up with the motherboard.
Great work and thanks for the help!
Todd - 回复 分享
Hello,
i would like to ask some help. I did everything exactly as you mentioned upper, however my screen is not able to handle my touch. Do you have any opinion what should be the problem?
Rgs,
B
Blaze - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 9
过去 30 天: 44
总计 12,335
