跳转到主内容
加入维修社区 - 创建账户
Nextbook Premium 7SE Volume Buttons Replacement
你所需要的
    1. Nextbook Premium 7SE Volume Buttons Replacement, Back Cover: 步骤 1 中的图像 1,3 Nextbook Premium 7SE Volume Buttons Replacement, Back Cover: 步骤 1 中的图像 2,3 Nextbook Premium 7SE Volume Buttons Replacement, Back Cover: 步骤 1 中的图像 3,3
      • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
      • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
      • Avoid prying on the buttons, as they are easily damaged.
      询问修复机器人
      添加评论
    2. Nextbook Premium 7SE Volume Buttons Replacement: 步骤 2 中的图像 1,1
      • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
      询问修复机器人
      添加评论
    1. Nextbook Premium 7SE Volume Buttons Replacement, Battery: 步骤 3 中的图像 1,1
      • Remove masking tape from the battery.
      询问修复机器人
      添加评论
    2. Nextbook Premium 7SE Volume Buttons Replacement: 步骤 4 中的图像 1,3 Nextbook Premium 7SE Volume Buttons Replacement: 步骤 4 中的图像 2,3 Nextbook Premium 7SE Volume Buttons Replacement: 步骤 4 中的图像 3,3
      • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
      • Handle the battery with care to avoid damaging it.
      询问修复机器人
      添加评论
    3. Nextbook Premium 7SE Volume Buttons Replacement: 步骤 5 中的图像 1,3 Nextbook Premium 7SE Volume Buttons Replacement: 步骤 5 中的图像 2,3 Nextbook Premium 7SE Volume Buttons Replacement: 步骤 5 中的图像 3,3
      • De-solder the three contact points and remove the battery.
      • See the following guide for instructions on how to solder. 如何焊接和拆焊
      • Use caution when operating the soldering iron.
      询问修复机器人
      添加评论
    1. Nextbook Premium 7SE Volume Buttons Replacement, Motherboard: 步骤 6 中的图像 1,3 Nextbook Premium 7SE Volume Buttons Replacement, Motherboard: 步骤 6 中的图像 2,3 Nextbook Premium 7SE Volume Buttons Replacement, Motherboard: 步骤 6 中的图像 3,3
      • Remove the two ZIF connectors attached to the motherboard by flipping up the black tabs before pulling the ribbon cable away.
      • Only use a fingernail or nylon spudger to flip up the retaining flap. Using metal tools may damage delicate components.
      询问修复机器人
      添加评论
    2. Nextbook Premium 7SE Volume Buttons Replacement: 步骤 7 中的图像 1,1
      • Use the nut driver and J00 bit to remove the three 4 mm screws.
      询问修复机器人
      添加评论
    3. Nextbook Premium 7SE Volume Buttons Replacement: 步骤 8 中的图像 1,3 Nextbook Premium 7SE Volume Buttons Replacement: 步骤 8 中的图像 2,3 Nextbook Premium 7SE Volume Buttons Replacement: 步骤 8 中的图像 3,3
      • Peel back metal tape that is hiding the auxiliary port wires.
      • Remove tape that is holding the speaker wires in place.
      • Lift up on the motherboard to release it from the tablet.
      询问修复机器人
      添加评论
    1. Nextbook Premium 7SE Volume Buttons Replacement, Volume Buttons: 步骤 9 中的图像 1,1
      • De-solder volume buttons' eight contact points.
      • Each button has 4 points of contact.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Baylor, Team 4-1, Williams Fall 2016 Baylor, Team 4-1, Williams Fall 2016 的会员
BU-WILLIAMS-F16S4G1
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 33
总计 459
