跳转到主内容
加入维修社区 - 创建账户
Nextbook Premium 7SE Battery Replacement
你所需要的
    1. Nextbook Premium 7SE Battery Replacement, Back Cover: 步骤 1 中的图像 1,3 Nextbook Premium 7SE Battery Replacement, Back Cover: 步骤 1 中的图像 2,3 Nextbook Premium 7SE Battery Replacement, Back Cover: 步骤 1 中的图像 3,3
      • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
      • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
      • Avoid prying on the buttons, as they are easily damaged.
      询问修复机器人
      添加评论
    2. Nextbook Premium 7SE Battery Replacement: 步骤 2 中的图像 1,1
      • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
      询问修复机器人
      添加评论
    1. Nextbook Premium 7SE Battery Replacement, Battery: 步骤 3 中的图像 1,1
      • Remove masking tape from the battery.
      询问修复机器人
      添加评论
    2. Nextbook Premium 7SE Battery Replacement: 步骤 4 中的图像 1,3 Nextbook Premium 7SE Battery Replacement: 步骤 4 中的图像 2,3 Nextbook Premium 7SE Battery Replacement: 步骤 4 中的图像 3,3
      • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
      • Handle the battery with care to avoid damaging it.
      询问修复机器人
      添加评论
    3. Nextbook Premium 7SE Battery Replacement: 步骤 5 中的图像 1,3 Nextbook Premium 7SE Battery Replacement: 步骤 5 中的图像 2,3 Nextbook Premium 7SE Battery Replacement: 步骤 5 中的图像 3,3
      • De-solder the three contact points and remove the battery.
      • See the following guide for instructions on how to solder. 如何焊接和拆焊
      • Use caution when operating the soldering iron.
      询问修复机器人
      添加评论
结论
To reassemble your device, follow these instructions in reverse order, being careful when re-soldering the contacts back into place.
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Baylor, Team 4-1, Williams Fall 2016 Baylor, Team 4-1, Williams Fall 2016 的会员
BU-WILLIAMS-F16S4G1
4 名成员
创作了35篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 1,029
