简介
Use this guide to replace a malfunctioning battery. This replacement guide requires a Soldering Iron, it would be very helpful to heat the iron up before starting this guide, this process can take 3-4 minutes. You should refer to iFixit's soldering guide to help with the desoldering/soldering process.
你所需要的
Using your finger, open the plastic tab to the right of the rear-facing camera.
Wedge your fingernail in between the back panel and the plastic tab and pull the plastic tab towards your body.
4等其他人完成本指南。
3指南评论
Excellent guide, easy to follow, very concise, very good photographs. Thank you
Donde puedo encontrar una batería
Lauraelena - 回复 分享
