跳转到主内容
加入维修社区 - 创建账户
New Nintendo 2DS XL Motherboard Replacement
你所需要的
    1. New Nintendo 2DS XL Motherboard Replacement, Prepare for disassembly: 步骤 1 中的图像 1,1
      • Before you begin, power off the console and remove:
      • The stylus
      • Any game cartridge
      • The microSD card
      添加评论
    2. New Nintendo 2DS XL Motherboard Replacement, Remove the back cover screws: 步骤 2 中的图像 1,1
      • Use a tri‑point Y00 screwdriver to remove the four 6 mm‑long screws located at the four corners of the bottom panel.
      添加评论
    3. New Nintendo 2DS XL Motherboard Replacement, Release the back cover clips: 步骤 3 中的图像 1,2 New Nintendo 2DS XL Motherboard Replacement, Release the back cover clips: 步骤 3 中的图像 2,2
      • Use a spudger to gently pry around the two short edges and front edge (with the stylus cut‑out) to release the clips securing the back cover.
      • Swing the back cover open from its front edge to release the clips along the hinge edge. Don't remove it fully—three cables are connecting it to the motherboard (two on each side and one in the rear).
      添加评论
    4. New Nintendo 2DS XL Motherboard Replacement, Disconnect the back cover: 步骤 4 中的图像 1,3 New Nintendo 2DS XL Motherboard Replacement, Disconnect the back cover: 步骤 4 中的图像 2,3 New Nintendo 2DS XL Motherboard Replacement, Disconnect the back cover: 步骤 4 中的图像 3,3
      在这个步骤中使用的工具:
      • Use tweezers to disconnect the two cables that connect the rear buttons on either side to the motherboard by gently pulling them upwards.
      • Fold the back cover over the hinge edge, keeping the cable connected. Don't strain the cable.
      添加评论
    5. New Nintendo 2DS XL Motherboard Replacement, Battery Removal: 步骤 5 中的图像 1,2 New Nintendo 2DS XL Motherboard Replacement, Battery Removal: 步骤 5 中的图像 2,2
      • The battery is lightly adhered to its enclosure.
      • Use the flat end of a spudger to gently pry the battery out of its plastic enclosure.
      添加评论
    1. New Nintendo 2DS XL Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,2 New Nintendo 2DS XL Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,2
      在这个步骤中使用的工具:
      • There are 8 ribbon cables that need to be removed as shown in the picture.
      • 2 of connectors (in green) are friction fit, unlike the rest of the connectors. Remove the cable by pulling it out gently flat in the arrow direction. Do not attempt to open or unlatch these connectors in any way. Doing so will break them.
      • For the remaining 6 (in red), use a pair of tweezers to flip the latches up and pull the ribbon cable out.
      • Note that the second picture shows a broken ribbon connector next to the joystick ribbon connector (to the right of the red arrow). Do not attempt to unlatch this connector as shown in the picture!
      添加评论
    2. New Nintendo 2DS XL Motherboard Replacement: 步骤 7 中的图像 1,2 New Nintendo 2DS XL Motherboard Replacement: 步骤 7 中的图像 2,2
      • Unplug the following wires from the motherboard using a pair of tweezers.
      询问修复机器人
      添加评论
    3. New Nintendo 2DS XL Motherboard Replacement: 步骤 8 中的图像 1,2 New Nintendo 2DS XL Motherboard Replacement: 步骤 8 中的图像 2,2
      • Remove the seven 4.4 mm screws using a J00 (or iFixit's Phillips #00) screwdriver bit.
      • Remove the motherboard from the device.
      添加评论
结论
取消:我没有完成这个指南。
13等其他人完成本指南。
团队
IUPUI, Team S1-G4, Harley Fall 2019 IUPUI, Team S1-G4, Harley Fall 2019 的会员
IUPUI-HARLEY-F19S1G4
3 名成员
创作了24篇指南
7指南评论
On step 6, what is the top left circled connector for?
The screen on the device I am repairing keeping going black and this connector is damaged. (it doesn’t clamp shut)
Can anyone recommend where to buy a replacement board connector?
Billy Holliday - 回复 分享
This doesn’t actually give ALL the tools you need. You can’t use a Tri point screwdriver on the CROSS screws that are in the pictures on the motherboard.
tomh1512 - 回复 分享
I know this might be a year too late, but the tri point is required for removing the back plate of the system. If you don't have a small philips head laying around your house, idk what to tell ya
Zach Cunningham - 回复 分享
Followed on a 2ds having bad input feedback, no major issue. screws on motherboard are cross so you need a small one (most diy nintendo kits have one) and a small clamp (like the one in pictures) is mandatory for the 7 small cables. there is something a bit tricky regarding volume button which is a bit hard to get back in place when you reassemble the console, take care of pushing the inner slider to the most far position for easier mounting.
Arnaud “Kilbane” Jamet - 回复 分享
I opened the friction fit connectors before reading this, but I pushed them back down and now my 2ds won't boot. I even tried holding them down to make contact but it still just flashes the backlight and shuts off...
Tipsy The Cat - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 27
过去 7 天: 132
过去 30 天: 546
总计 24,500
