跳转到主内容
NVIDIA GeForce GTX 970 GPU Replacement
Nicholas Eichman
Nicholas Eichman2 其他贡献者
最后更新于 February 21, 2023
10 - 15 分钟
简单
Use this guide to replace a faulty or outdated GPU, in this case, an NVIDIA GeForce GTX 970 in a HAF 912 case.
The graphics card, or GPU, is a piece of hardware that allows a computer to display images and videos more effectively. A failing video card can lead to crashes and issues running certain software.
你所需要的
工具
  1. NVIDIA GeForce GTX 970 GPU Replacement, GPU: 步骤 1 中的图像 1,2 NVIDIA GeForce GTX 970 GPU Replacement, GPU: 步骤 1 中的图像 2,2
    • Unplug all the external cables from the computer and ensure that the power supply is switched off.
  2. NVIDIA GeForce GTX 970 GPU Replacement: 步骤 2 中的图像 1,2 NVIDIA GeForce GTX 970 GPU Replacement: 步骤 2 中的图像 2,2
    • Remove the case side panel by applying pressure to the side and sliding the side panel toward the back of the case.
    • Some cases may have screws that must be removed or tabs that must be pressed before the siding will slide off.
  3. NVIDIA GeForce GTX 970 GPU Replacement: 步骤 3 中的图像 1,3 NVIDIA GeForce GTX 970 GPU Replacement: 步骤 3 中的图像 2,3 NVIDIA GeForce GTX 970 GPU Replacement: 步骤 3 中的图像 3,3
    • Pinch the lock at the end of the GPU power cable and carefully disconnect it.
  4. NVIDIA GeForce GTX 970 GPU Replacement: 步骤 4 中的图像 1,3 NVIDIA GeForce GTX 970 GPU Replacement: 步骤 4 中的图像 2,3 NVIDIA GeForce GTX 970 GPU Replacement: 步骤 4 中的图像 3,3
    • Remove the two Philips #1 mounting screws that attach the GPU to the inside of the case.
  5. NVIDIA GeForce GTX 970 GPU Replacement: 步骤 5 中的图像 1,3 NVIDIA GeForce GTX 970 GPU Replacement: 步骤 5 中的图像 2,3 NVIDIA GeForce GTX 970 GPU Replacement: 步骤 5 中的图像 3,3
    • Press down the locking tab at the base of the GPU.
  6. NVIDIA GeForce GTX 970 GPU Replacement: 步骤 6 中的图像 1,1
    • Remove the GPU from the case. If it does not move, check to make sure that steps 3-5 were properly performed.
  7. NVIDIA GeForce GTX 970 GPU Replacement: 步骤 7 中的图像 1,2 NVIDIA GeForce GTX 970 GPU Replacement: 步骤 7 中的图像 2,2
    • When inserting a replacement GPU, ensure that the base is lined up properly with the appropriate slot on the motherboard.
    • Once the replacement GPU is lined up, press down until you hear a click or can see that the locking tab is flipped up again.
结论
To finish reassembly, follow steps 2-4 in reverse order.
11等其他人完成本指南。
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 57
过去 30 天: 132
总计 7,584
