本指南有最近更改,您可查看未经巡查的最新版本。
简介
Follow this guide to remove the motherboard on the Motorola Moto X4.
你所需要的
Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole in the SIM card tray, located at the top left edge of the phone.
Press to eject the tray.
Remove the tray from the phone.
Heat an iOpener and apply it to the left edge of the phone for two minutes.
As you wait, take note of the the following areas:
Display cable—be careful not to slice too deeply near the edge here, or you may damage the display cable.
Fingerprint sensor cable—be careful not to slice too deeply near the edge here, or you may damage the fingerprint sensor cable.
Apply a suction cup to the screen, as close to the heated edge as possible.
Pull on the suction cup with strong, steady force to create a gap in the seam.
Insert the point of an opening pick into the gap.
Slide the opening pick along the edge to slice through the adhesive.
Leave an opening pick in the seam to prevent the adhesive from re-sealing.
Slide the point of a spudger underneath the fingerprint sensor cable and gently pry up to loosen the cable from the phone.
Use an opening tool to flip up the wide lock bar on the display cable's ZIF socket, near the top right of the phone.
Use tweezers to carefully slide the display cable out of the ZIF socket.
Remove the following twenty screws securing the midframe:
Eleven silver 2.7 mm-long T3 screws
Nine black 3.6 mm-long T4 screws
The midframe is still held in place by clips.
Insert the flat end of a spudger under the right edge of the metal midframe and pry up to loosen the midframe.
Insert an opening pick in the edge to hold the midframe in place.
Remove the midframe.
Align the the midframe's top edge to the phone and press it into position.
Shift the bottom edge slightly to the left, to maneuver the left metal midframe clip underneath the phone edge.
Press the midframe's bottom edge into position.
Insert the point of a spudger underneath the top edge of the battery connector.
Gently pry up the connector to disconnect the battery.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Motorola Moto X4 Answers community for help.
7等其他人完成本指南。
8条评论
I have Moto x4 mother board
Can you call me 833100taa1
I am from Hyderabad i need moto X4 mother board
Anana malladi r y working at
