跳转到主内容
Motorola Moto G5 Battery Replacement
你所需要的
  1. Motorola Moto G5 Battery Replacement, Back Cover: 步骤 1 中的图像 1,2 Motorola Moto G5 Battery Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
    • Pry with your fingernail or twist the spudger to release the back cover from the phone.
  2. Motorola Moto G5 Battery Replacement: 步骤 2 中的图像 1,3 Motorola Moto G5 Battery Replacement: 步骤 2 中的图像 2,3 Motorola Moto G5 Battery Replacement: 步骤 2 中的图像 3,3
    • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
  3. Motorola Moto G5 Battery Replacement: 步骤 3 中的图像 1,3 Motorola Moto G5 Battery Replacement: 步骤 3 中的图像 2,3 Motorola Moto G5 Battery Replacement: 步骤 3 中的图像 3,3
    • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
  4. Motorola Moto G5 Battery Replacement: 步骤 4 中的图像 1,2 Motorola Moto G5 Battery Replacement: 步骤 4 中的图像 2,2
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto G5 Battery Replacement, Battery: 步骤 5 中的图像 1,2 Motorola Moto G5 Battery Replacement, Battery: 步骤 5 中的图像 2,2
    • Insert your fingernail or the flat end of the spudger into the notch below the battery.
    • Pry with your fingernail or spudger until you free the battery from its recess.
  6. Motorola Moto G5 Battery Replacement: 步骤 6 中的图像 1,1
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
结论
After completing this guide, calibrate your newly-installed battery.
Repair didn’t go as planned? Check out our Motorola Moto G5 Answers community for troubleshooting help.
9等其他人完成本指南。
Arthur Shi
于01/03/18注册
257,465 声望
创作了529篇指南
团队
iFixit iFixit 的会员
Staff
141 名成员
创作了17,895篇指南
5条评论
this is not the g5 replacement procedure. it will not work.need to remove screen.
Tom Tercek - 回复
@Tom Tercek - You are in a huge mistake. This is the Motorola Moto G5 phone and the battery is removable and as shown on the pics, very easy to replace.
prishylets - 回复
is it also possible with moto g5s?
Jojo Blublub - 回复
Unfortunately, the G5S does not have an easily replaceable battery.
Arthur Shi -
Hi, I'm looking for parts for Moto G5, specifically an intern plastic cover that goes over the charge port.
Leonardo - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 87
过去 30 天: 386
总计 40,085
