跳转到主内容
Motorola Moto G Stylus 5G (2022) Back Cover Replacement
你所需要的
  1. Motorola Moto G Stylus 5G (2022) Back Cover Replacement, Heat the edge: 步骤 1 中的图像 1,1
    • Discharge your battery to 25% or lower and power off your phone before you begin.
    • Heat an iOpener and apply it to the edge of the back cover with the SIM card slot for two minutes.
    • A hair dryer or heat gun may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Motorola Moto G Stylus 5G (2022) Back Cover Replacement, Insert an opening pick: 步骤 2 中的图像 1,3 Motorola Moto G Stylus 5G (2022) Back Cover Replacement, Insert an opening pick: 步骤 2 中的图像 2,3 Motorola Moto G Stylus 5G (2022) Back Cover Replacement, Insert an opening pick: 步骤 2 中的图像 3,3
    • Apply a suction cup to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the cover and the frame.
    • Insert an opening pick into the gap.
  3. Motorola Moto G Stylus 5G (2022) Back Cover Replacement, Slice the right adhesive: 步骤 3 中的图像 1,3 Motorola Moto G Stylus 5G (2022) Back Cover Replacement, Slice the right adhesive: 步骤 3 中的图像 2,3 Motorola Moto G Stylus 5G (2022) Back Cover Replacement, Slice the right adhesive: 步骤 3 中的图像 3,3
    • Slide your opening pick back and forth along the right edge to slice through the adhesive.
    • Leave the pick in at the bottom right corner to prevent the adhesive from resealing.
  4. Motorola Moto G Stylus 5G (2022) Back Cover Replacement, Slice the bottom adhesive: 步骤 4 中的图像 1,2 Motorola Moto G Stylus 5G (2022) Back Cover Replacement, Slice the bottom adhesive: 步骤 4 中的图像 2,2
    • Insert a second opening pick into the bottom right corner.
    • Slide this opening pick along the bottom edge to the bottom left corner to slice through the adhesive.
    • Leave the pick inserted to prevent the bottom edge from resealing.
  5. Motorola Moto G Stylus 5G (2022) Back Cover Replacement, Slice the left adhesive: 步骤 5 中的图像 1,3 Motorola Moto G Stylus 5G (2022) Back Cover Replacement, Slice the left adhesive: 步骤 5 中的图像 2,3 Motorola Moto G Stylus 5G (2022) Back Cover Replacement, Slice the left adhesive: 步骤 5 中的图像 3,3
    • Insert a third opening pick into the bottom right corner.
    • Slide this opening pick along the left edge to slice the adhesive.
    • Don't worry about slicing under the camera bezel. It's separate from the back cover and will be removed later.
    • Leave the pick inserted in the top left corner to prevent the left edge from resealing.
  6. Motorola Moto G Stylus 5G (2022) Back Cover Replacement, Slice the top adhesive: 步骤 6 中的图像 1,2 Motorola Moto G Stylus 5G (2022) Back Cover Replacement, Slice the top adhesive: 步骤 6 中的图像 2,2
    • Insert a fourth pick into the top left corner.
    • Slide the pick to the top right corner to slice the top adhesive.
  7. Motorola Moto G Stylus 5G (2022) Back Cover Replacement, Slice around the camera bezel: 步骤 7 中的图像 1,1
    • Slide an opening pick between the camera bezel and the back cover.
    • The back cover's adhesive is particularly strong around the camera bezel.
    • Slide the opening pick around the camera bezel to separate the back cover from the frame.
  8. Motorola Moto G Stylus 5G (2022) Back Cover Replacement, Remove the back cover: 步骤 8 中的图像 1,3 Motorola Moto G Stylus 5G (2022) Back Cover Replacement, Remove the back cover: 步骤 8 中的图像 2,3 Motorola Moto G Stylus 5G (2022) Back Cover Replacement, Remove the back cover: 步骤 8 中的图像 3,3
    • Grab and remove the back cover by lifting it away from the phone.
    • If your back cover is still sticking to the frame, slide the pick around the edges of the phone to slice through any remaining adhesive.
    • Reassembly notes:
    • To adhere the back cover with custom-cut adhesives, follow this guide.
    • To adhere the back cover with tape, follow this guide.
结论
Clay Eickemeyer
于09/19/22注册
67,399 声望
创作了453篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,430篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 24
过去 30 天: 101
总计 1,693
