跳转到主内容
Motorola Moto E Volume and Power Buttons Replacement
Alex Craig
Alex Craig4 其他贡献者
最后更新于 May 15, 2023
30分钟 - 1小时
中等
要点符号!
详尽分析
In order to access the volume and power buttons for replacement, you need to completely disassemble the device. Pay special attention to the directions the buttons are facing because they only fit one way.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
你所需要的
工具
查看更多...
  1. Motorola Moto E Volume and Power Buttons Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Turn off the device before beginning.
    • To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
    • With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
    • You should hear a snapping sound at each corner.
  2. Motorola Moto E Volume and Power Buttons Replacement: 步骤 2 中的图像 1,1
    • Unscrew the 14- 4mm screws using a T4 Torx driver head.
    • Working on a magnet board is recommended as the screws are small and can be easily misplaced.
  3. Motorola Moto E Volume and Power Buttons Replacement: 步骤 3 中的图像 1,1
    • Using the same plastic opening tool as in step 1, once again pry up on the edges of the plastic back cover.
    • Be sure that all of the screws are out before lifting the cover. The plastic backing is fragile, and it may break.
  4. Motorola Moto E Volume and Power Buttons Replacement: 步骤 4 中的图像 1,1
    • Gently lift the back plate away, exposing the motherboard. The battery will be stuck to the back of the cover, so be careful when lifting it off.
    • Do not touch the connections to the battery in the red square on the picture.
  5. Motorola Moto E Volume and Power Buttons Replacement: 步骤 5 中的图像 1,1
    • Gently pull up on the red and black power cable to lift the connector out of the motherboard.
    • Move the battery and cover away from the motherboard.
  6. Motorola Moto E Volume and Power Buttons Replacement: 步骤 6 中的图像 1,1
    • Unscrew the 3- 1mm screws using the T4 torx driver head.
  7. Motorola Moto E Volume and Power Buttons Replacement: 步骤 7 中的图像 1,1
    • Lift up on the white plastic mount.
    • Pull the orange ribbon cable out gently.
  8. Motorola Moto E Volume and Power Buttons Replacement: 步骤 8 中的图像 1,2 Motorola Moto E Volume and Power Buttons Replacement: 步骤 8 中的图像 2,2
    • Gently pull the black ribbon cable out.
  9. Motorola Moto E Volume and Power Buttons Replacement: 步骤 9 中的图像 1,1
    • Using the metal spudger, pry the motherboard away from the screen assembly.
  10. Motorola Moto E Volume and Power Buttons Replacement, Volume and Power Buttons: 步骤 10 中的图像 1,1
    • Locate the 3 tabs on the backs of the volume and power buttons.
    • Press firmly on the tabs using the plastic spudger until they pop out.
  11. Motorola Moto E Volume and Power Buttons Replacement: 步骤 11 中的图像 1,1
    • Press the new buttons into the assemblies.
    • Be sure the new buttons are facing the correct direction. The outside of the button should match the shape of the hole.
结论
9等其他人完成本指南。
Alex Craig
于03/11/15注册
2,611 声望
创作了5篇指南
团队
Colorado Springs, Team 5-7, Panko Spring 2015 Colorado Springs, Team 5-7, Panko Spring 2015 的会员
UCCS-PANKO-S15S5G7
2 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 39
总计 23,002
