跳转到主内容
加入维修社区 - 创建账户
Motorola Edge Interconnect Cable Replacement
你所需要的
  1. Motorola  Edge Interconnect Cable Replacement, Heat the bottom edge: 步骤 1 中的图像 1,1
    • Completely power off your phone before you begin.
    • Heat an iOpener, then apply it along the bottom edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone because the display and internal battery are both susceptible to heat damage.
  2. Motorola  Edge Interconnect Cable Replacement, Separate the bottom adhesive: 步骤 2 中的图像 1,3 Motorola  Edge Interconnect Cable Replacement, Separate the bottom adhesive: 步骤 2 中的图像 2,3 Motorola  Edge Interconnect Cable Replacement, Separate the bottom adhesive: 步骤 2 中的图像 3,3
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
  3. Motorola  Edge Interconnect Cable Replacement, Slice the bottom adhesive: 步骤 3 中的图像 1,3 Motorola  Edge Interconnect Cable Replacement, Slice the bottom adhesive: 步骤 3 中的图像 2,3 Motorola  Edge Interconnect Cable Replacement, Slice the bottom adhesive: 步骤 3 中的图像 3,3
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Leave the pick in to prevent the adhesive from resealing.
  4. Motorola  Edge Interconnect Cable Replacement, Heat the right edge: 步骤 4 中的图像 1,1
    • Apply a heated iOpener to the back cover's right edge for two minutes.
  5. Motorola  Edge Interconnect Cable Replacement, Separate the corner adhesive: 步骤 5 中的图像 1,3 Motorola  Edge Interconnect Cable Replacement, Separate the corner adhesive: 步骤 5 中的图像 2,3 Motorola  Edge Interconnect Cable Replacement, Separate the corner adhesive: 步骤 5 中的图像 3,3
    • Rotate the opening pick around the bottom-right corner of the phone.
  6. Motorola  Edge Interconnect Cable Replacement, Separate the right adhesive: 步骤 6 中的图像 1,3 Motorola  Edge Interconnect Cable Replacement, Separate the right adhesive: 步骤 6 中的图像 2,3 Motorola  Edge Interconnect Cable Replacement, Separate the right adhesive: 步骤 6 中的图像 3,3
    • Insert a new opening pick into the gap you just created.
    • Slide the pick along the right edge of the phone to separate the adhesive.
    • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
  7. Motorola  Edge Interconnect Cable Replacement, Remove the back cover: 步骤 7 中的图像 1,3 Motorola  Edge Interconnect Cable Replacement, Remove the back cover: 步骤 7 中的图像 2,3 Motorola  Edge Interconnect Cable Replacement, Remove the back cover: 步骤 7 中的图像 3,3
    • Remove the back cover, taking care not to damage the components inside the phone.
  8. Motorola  Edge Interconnect Cable Replacement, Remove the motherboard's screws: 步骤 8 中的图像 1,1
    • Use a T5 Torx screwdriver to remove the twelve 3.4 mm-long screws securing the motherboard cover.
  9. Motorola  Edge Interconnect Cable Replacement, Remove the motherboard cover: 步骤 9 中的图像 1,3 Motorola  Edge Interconnect Cable Replacement, Remove the motherboard cover: 步骤 9 中的图像 2,3 Motorola  Edge Interconnect Cable Replacement, Remove the motherboard cover: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of blunt tweezers or your fingers to lift up and remove the motherboard cover.
    • The motherboard cover also contains the phone's flash.
  10. Motorola  Edge Interconnect Cable Replacement, Disconnect the battery cable's press connector: 步骤 10 中的图像 1,2 Motorola  Edge Interconnect Cable Replacement, Disconnect the battery cable's press connector: 步骤 10 中的图像 2,2
    • Use a spudger to pry up and disconnect the battery cable's press connector from the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  11. Motorola  Edge Interconnect Cable Replacement, Remove the daughterboard's t5 screws: 步骤 11 中的图像 1,2 Motorola  Edge Interconnect Cable Replacement, Remove the daughterboard's t5 screws: 步骤 11 中的图像 2,2
    • Use a T5 Torx screwdriver to remove the nine 3.4 mm screws securing the daughterboard.
  12. Motorola  Edge Interconnect Cable Replacement, Remove the daughterboard cover: 步骤 12 中的图像 1,3 Motorola  Edge Interconnect Cable Replacement, Remove the daughterboard cover: 步骤 12 中的图像 2,3 Motorola  Edge Interconnect Cable Replacement, Remove the daughterboard cover: 步骤 12 中的图像 3,3
    • Use a spudger to pry up the plastic daughterboard cover and disconnect it from the rest of the phone.
  13. Motorola  Edge Interconnect Cable Replacement, Disconnect the interconnect cable from the motherboard: 步骤 13 中的图像 1,2 Motorola  Edge Interconnect Cable Replacement, Disconnect the interconnect cable from the motherboard: 步骤 13 中的图像 2,2
    • Use a spudger to pry up and disconnect the interconnect cable's press connector from the motherboard.
  14. Motorola  Edge Interconnect Cable Replacement, Disconnect the interconnect cable from the daughterboard: 步骤 14 中的图像 1,2 Motorola  Edge Interconnect Cable Replacement, Disconnect the interconnect cable from the daughterboard: 步骤 14 中的图像 2,2
    • Use a spudger to pry up and disconnect the interconnect cable's press connector from the daughterboard.
  15. Motorola  Edge Interconnect Cable Replacement, Remove the interconnect cable: 步骤 15 中的图像 1,2 Motorola  Edge Interconnect Cable Replacement, Remove the interconnect cable: 步骤 15 中的图像 2,2
    • Use your fingers to remove the interconnect cable after it has been disconnected from both the motherboard and daughterboard.
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Jennifer Berg
于03/21/22注册
2,849 声望
创作了24篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 236
