跳转到主内容
加入维修社区 - 创建账户
Microsoft Surface Pro Camera Replacement
你所需要的
    1. Microsoft Surface Pro Camera Replacement, Heat edges of display: 步骤 1 中的图像 1,1
      • Use a heated iOpener or a heat gun to heat the edges of the display and soften its adhesive.
      • If you're using an iOpener it may take several cycles of reheating and applying it to soften the adhesive enough. Every time, let the iOpener sit on the display for at least a minute before reheating to allow the adhesive to soften.
      添加评论
    2. Microsoft Surface Pro Camera Replacement, Lift display and cut adhesive: 步骤 2 中的图像 1,3 Microsoft Surface Pro Camera Replacement, Lift display and cut adhesive: 步骤 2 中的图像 2,3 Microsoft Surface Pro Camera Replacement, Lift display and cut adhesive: 步骤 2 中的图像 3,3
      • Apply a suction cup as close as possible to the edge of the display.
      • Use the suction cup to lift the edge of the display enough to insert an opening pick under the edge.
      • Slide the opening pick all the way around the edges of the display to cut through the adhesive on the bezel.
      • Do not insert the opening pick past the bezel of the display—you may permanently damage the display.
      • The bezel is much thinner on the bottom of the display, which is the side with the Windows logo. To avoid damage, don't poke too deep with the opening pick on the bottom edge.
      • Ribbon cables and a circuit board are approx. 0.6 cm from the edge of the glass.
      • Be very careful and move slowly during this step. The display is fragile and will crack if too much force is applied against it. If your tools seem stuck, apply more heat to further soften the adhesive.
      询问修复机器人
      添加评论
    3. Microsoft Surface Pro Camera Replacement, Disconnect/peel off ribbon cables: 步骤 3 中的图像 1,3 Microsoft Surface Pro Camera Replacement, Disconnect/peel off ribbon cables: 步骤 3 中的图像 2,3 Microsoft Surface Pro Camera Replacement, Disconnect/peel off ribbon cables: 步骤 3 中的图像 3,3
      • Starting from the top edge, lift the display slightly.
      • If you feel any resistance, use heat and an opening pick to slice through any remaining adhesive.
      • Before completely removing the display:
      • Disconnect the three display cables.
      • Gently peel from the frame 2 orange ribbon cables that are glued to it, as those should stay with the display. (e.g. use a thin plastic card to separate them)
      添加评论
    4. Microsoft Surface Pro Camera Replacement, Removal: 步骤 4 中的图像 1,1
      • Remove the display.
      询问修复机器人
      添加评论
    1. Microsoft Surface Pro Camera Replacement, Camera: 步骤 5 中的图像 1,2 Microsoft Surface Pro Camera Replacement, Camera: 步骤 5 中的图像 2,2
      • Using a T5 Torx screwdriver, unscrew a total number of 23 screws located on the outside panel of the Surface Pro.
      询问修复机器人
      添加评论
    2. Microsoft Surface Pro Camera Replacement: 步骤 6 中的图像 1,1
      • Use the plastic opening tool or fingers to pry out the front camera.
      询问修复机器人
      添加评论
    3. Microsoft Surface Pro Camera Replacement: 步骤 7 中的图像 1,1
      • Lift the outside panel from the Surface Pro.
      询问修复机器人
      添加评论
    4. Microsoft Surface Pro Camera Replacement: 步骤 8 中的图像 1,2 Microsoft Surface Pro Camera Replacement: 步骤 8 中的图像 2,2
      • Use the plastic opening tool to pry out the back camera.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Jonathan Choi
于10/09/13注册
1,090 声望
创作了4篇指南
团队
Cal Poly, Team 8-20, Regan Fall 2013 Cal Poly, Team 8-20, Regan Fall 2013 的会员
CPSU-REGAN-F13S8G20
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 21
过去 30 天: 53
总计 5,056
