简介
Follow this guide to replace a broken fan in your Microsoft Surface Laptop 7 (13.8‑inch).
If your fan is spinning erratically, constantly, or not at all, it may be time to replace it.
你所需要的
Gently slide one arm of your angled tweezers into the recess near the upper right edge of one of the feet.
Use your tweezers to pry up and remove the foot.
Repeat the process to remove the remaining feet.
在这个步骤中使用的工具:FixMat$36.95
Use a Torx Plus 5IP screwdriver to remove the four 4.5 mm‑long screws (with washers) securing the lower case.
Insert the tip of an opening pick under the top edge of the lower case, about an inch (2.5 cm) to the left or right of the Microsoft logo.
Use a Torx Plus 3IP screwdriver to remove the two 2.3 mm‑long screws securing the battery connector cover.
Insert the flat end of a spudger under the top edge of the battery press connector and pry up to disconnect it.
Use the flat end of a spudger to flip up the metal buckle on the Surface Connect port connector.
Use a Torx Plus 3IP screwdriver to remove the two 3 mm‑long screws securing the Surface Connect port to the top left corner of the frame.
Heat an iOpener and lay it on the Surface Connect port cable for two minutes to soften the adhesive.
在这个步骤中使用的工具:Tesa 61395 Tape$2.99
Grip the Surface Connect cable close to the motherboard connector and peel the cable from the fan.
If the tape is still sticky, you don't need to replace it.
If the adhesive is no longer sticky, or if you're replacing the fan and it doesn't have adhesive, apply a new strip of thin, double-sided tape to the top edge of the fan.
Lift and remove the Surface Connect port.
Put the Surface Connect port into place so its cutouts go over their posts on the motherboard. Make sure the port is fully in its cutout—the outer edge should be flush with the frame.
Install the two screws that secure the port.
Use the point of a spudger to lift the hinged locking flap on the fan cable ZIF connector, located on the left edge of the motherboard.
Use tweezers to grip the fan cable's pull tab and slide the cable out of its socket.
Slide the point of a spudger under the speaker connector (just below the fan cable) and gently lift it straight up and out of the socket.
Use a Torx Plus 3IP screwdriver to remove the three 4.1 mm‑long screws securing the fan.
