跳转到主内容
加入维修社区 - 创建账户
Microsoft Surface Book 2 15" Front Camera Replacement
你所需要的
    1. Microsoft Surface Book 2 15" Front Camera Replacement, Motherboard: 步骤 1 中的图像 1,1
      • Open the laptop, then orient it so the touchpad is on your left.
      • Starting at the hinge, count six holes up on the tablet portion of the laptop.
      询问修复机器人
      添加评论
    2. Microsoft Surface Book 2 15" Front Camera Replacement: 步骤 2 中的图像 1,2 Microsoft Surface Book 2 15" Front Camera Replacement: 步骤 2 中的图像 2,2
      • Take a paper clip and unfold it.
      • Place the paper clip in the sixth hole and push until you hear a click.
      • Once you hear the click, lift up on the right side of the tablet from the base until it separates.
      • After the right side has been detached, lift up the left side as well.
      询问修复机器人
      添加评论
    3. Microsoft Surface Book 2 15" Front Camera Replacement: 步骤 3 中的图像 1,1
      • Place the tablet on a flat surface.
      • Using a heat gun or iOpener, heat up the edges of the screen to soften up the adhesive.
      询问修复机器人
      添加评论
    4. Microsoft Surface Book 2 15" Front Camera Replacement: 步骤 4 中的图像 1,1
      • Using a plastic pick, slice underneath the edge of the screen.
      • Use a suction cup to carefully lift the screen and create separation between the screen and frame.
      • Take care not to insert the tool too far to avoid cutting the ribbon cables.
      • Slowly make your way around the screen, and carefully cut the adhesive that secures the screen to the frame.
      • Don't use a metal tool, that could damage the screen or internal parts.
      添加评论
    5. Microsoft Surface Book 2 15" Front Camera Replacement: 步骤 5 中的图像 1,2 Microsoft Surface Book 2 15" Front Camera Replacement: 步骤 5 中的图像 2,2
      • Lift up the screen.
      • Detach the ribbon cables connecting the underside of the screen to the motherboard.
      询问修复机器人
      添加评论
    6. Microsoft Surface Book 2 15" Front Camera Replacement: 步骤 6 中的图像 1,2 Microsoft Surface Book 2 15" Front Camera Replacement: 步骤 6 中的图像 2,2
      • Use a T3 Torx screwdriver to remove eleven 4 mm screws from the motherboard.
      • Use a T3 Torx screwdriver to remove the ten 2.5 mm screws from the top bar.
      询问修复机器人
      添加评论
    7. Microsoft Surface Book 2 15" Front Camera Replacement: 步骤 7 中的图像 1,1
      • Once the screws are removed from the top bar, gently lift up and remove it.
      • Be careful not to damage any ribbon cables or wires.
      • Gently lift up on the motherboard to remove it.
      询问修复机器人
      添加评论
    1. Microsoft Surface Book 2 15" Front Camera Replacement, Front Camera: 步骤 8 中的图像 1,1
      • After lifting the motherboard, locate the two cameras near the center of the motherboard.
      • Unplug front camera (right side) from the motherboard (lift carefully).
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Colton Almeida
于03/13/23注册
172 声望
创作了2篇指南
团队
UMass Dartmouth, Team 3-3, Petersen Spring 2023 UMass Dartmouth, Team 3-3, Petersen Spring 2023 的会员
UMASSD-PETERSEN-S23S3G3
4 名成员
创作了54篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 28
总计 849
