跳转到主内容
加入维修社区 - 创建账户
Microsoft Surface 3 Kickstand Replacement
你所需要的
    1. Microsoft Surface 3 Kickstand Replacement, Casing: 步骤 1 中的图像 1,2 Microsoft Surface 3 Kickstand Replacement, Casing: 步骤 1 中的图像 2,2
      • Warm up an iOpener following the instructions found in the iOpener guide.
      • Place the warm iOpener on top of the edges of the screen. This heat will weaken the strength of the adhesive between the display and body.
      添加评论
    2. Microsoft Surface 3 Kickstand Replacement: 步骤 2 中的图像 1,2 Microsoft Surface 3 Kickstand Replacement: 步骤 2 中的图像 2,2
      • Use iFixit opening picks to wedge under the edge of the screen at the speaker port.
      • This may take significant force. A fingernail might work better for the initial lift
      • If you push straight down near the edge you will go through the speaker mesh and possibly end up damaging your speaker; try to push the pick in at a shallow angle.
      询问修复机器人
      添加评论
    3. Microsoft Surface 3 Kickstand Replacement: 步骤 3 中的图像 1,2 Microsoft Surface 3 Kickstand Replacement: 步骤 3 中的图像 2,2
      • Carefully try to work your way around the device using the picks, reapplications of the heated iOpener, and luck.
      • If you break the glass on one side you might want to try again starting from the other side so that you have a clean, unbroken, edge on that side.
      • While the glass on this display is not particularly sharp when broken, it is still broken glass and you should be careful with it.
      添加评论
    4. Microsoft Surface 3 Kickstand Replacement: 步骤 4 中的图像 1,1
      • Flip the display over so that parts underneath it are easily accessible.
      • Do not pull out the display as it is still attached to the motherboard.
      • If you are replacing the display, or want it out of the way, continue with the display replacement guide steps.
      添加评论
    1. Microsoft Surface 3 Kickstand Replacement, Battery: 步骤 5 中的图像 1,1
      • Now that you've gotten the casing off of the Surface 3, you can start removing the battery pack.
      询问修复机器人
      添加评论
    2. Microsoft Surface 3 Kickstand Replacement: 步骤 6 中的图像 1,3 Microsoft Surface 3 Kickstand Replacement: 步骤 6 中的图像 2,3 Microsoft Surface 3 Kickstand Replacement: 步骤 6 中的图像 3,3
      在这个步骤中使用的工具:
      Plastic Cards
      $2.99
      • Slide the iFixit plastic cards under the compartments of the battery pack.
      • Slide the card around to undo the adhesive under the battery pack
      询问修复机器人
      添加评论
    3. Microsoft Surface 3 Kickstand Replacement: 步骤 7 中的图像 1,3 Microsoft Surface 3 Kickstand Replacement: 步骤 7 中的图像 2,3 Microsoft Surface 3 Kickstand Replacement: 步骤 7 中的图像 3,3
      • Carefully slide the battery's flat power and data connector from its insert.
      • You may now switch out the battery pack for a new one.
      添加评论
    1. Microsoft Surface 3 Kickstand Replacement, Kickstand: 步骤 8 中的图像 1,2 Microsoft Surface 3 Kickstand Replacement, Kickstand: 步骤 8 中的图像 2,2
      • Remove these four 3/32" Torx #3 screws.
      • If you do not need to remove the hinges, skip to the step that handles the retaining tabs.
      询问修复机器人
      添加评论
    2. Microsoft Surface 3 Kickstand Replacement: 步骤 9 中的图像 1,2 Microsoft Surface 3 Kickstand Replacement: 步骤 9 中的图像 2,2
      • Remove these four 3/16" Torx #5 screws that hold in the hinges to replace the hinges.
      询问修复机器人
      添加评论
    3. Microsoft Surface 3 Kickstand Replacement: 步骤 10 中的图像 1,3 Microsoft Surface 3 Kickstand Replacement: 步骤 10 中的图像 2,3 Microsoft Surface 3 Kickstand Replacement: 步骤 10 中的图像 3,3
      • These two retaining tabs need to be fed through the slots in the case to release the kickstand.
      • Use picks to make the tab slide through the slot then simply pull out the kickstand,
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
Harold Hall
于10/08/15注册
1,332 声望
创作了3篇指南
团队
Cal Poly, Team 5-12, Maness Fall 2015 Cal Poly, Team 5-12, Maness Fall 2015 的会员
CPSU-MANESS-F15S5G12
4 名成员
创作了30篇指南
2指南评论
I think I will NOT be trying to do this. To many potentials for something to go wrong beyond your control, even when being extra careful. I do not feel like replacing someone’s device if that happens.
QuickTech - 回复 分享
Please can you tell me which kickstand the surface pro 3 64 GB (2013) needs? Is it the same as the surface pro 4 ? I have broken the stand and am trying yo source a replacement.
Tilly Mortimore - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 42
总计 10,110
