跳转到主内容
加入维修社区 - 创建账户
Meta Quest 2 Controller Ring Shell Replacement
你所需要的
    1. Meta Quest 2 Controller Ring Shell Replacement, Remove the battery cover: 步骤 1 中的图像 1,3 Meta Quest 2 Controller Ring Shell Replacement, Remove the battery cover: 步骤 1 中的图像 2,3 Meta Quest 2 Controller Ring Shell Replacement, Remove the battery cover: 步骤 1 中的图像 3,3
      • Use your fingers to slide the battery cover down towards the strap end of the controller.
      • Remove the battery cover.
      • If you're taking the controller apart for repairs, remove the batteries in the controller.
      添加评论
    1. Meta Quest 2 Controller Ring Shell Replacement, Remove the wrist strap: 步骤 2 中的图像 1,2 Meta Quest 2 Controller Ring Shell Replacement, Remove the wrist strap: 步骤 2 中的图像 2,2
      • Use your fingers to grasp the wrist strap near the anchor peg.
      • Lift the wrist strap anchor peg straight out of its recess.
      • Remove the wrist strap.
      询问修复机器人
      添加评论
    1. Meta Quest 2 Controller Ring Shell Replacement, Loosen the faceplate adhesive: 步骤 3 中的图像 1,1
      • Heat an iOpener and apply it to the bottom edge of the controller faceplate for a minute.
      添加评论
    2. Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller faceplate: 步骤 4 中的图像 1,3 Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller faceplate: 步骤 4 中的图像 2,3 Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller faceplate: 步骤 4 中的图像 3,3
      • The controller faceplate is secured with adhesive and three friction pegs.
      • Press the edge of an opening tool into the seam between the controller faceplate and shell, near the Oculus button.
      • If you can’t get the opening tool into the seam, heat the area with an iOpener for a minute and try again.
      • Slide the opening tool to the base of the ring shell to loosen the adhesive.
      询问修复机器人
      添加评论
    3. Meta Quest 2 Controller Ring Shell Replacement: 步骤 5 中的图像 1,2 Meta Quest 2 Controller Ring Shell Replacement: 步骤 5 中的图像 2,2
      • Use an opening tool to pry up on the seam to loosen the first friction peg.
      询问修复机器人
      添加评论
    4. Meta Quest 2 Controller Ring Shell Replacement: 步骤 6 中的图像 1,2 Meta Quest 2 Controller Ring Shell Replacement: 步骤 6 中的图像 2,2
      • Continue prying around the entire faceplate to separate the remaining friction pegs and adhesive.
      • If you're having trouble, apply a heated iOpener to the faceplate for a minute and try again.
      询问修复机器人
      添加评论
    5. Meta Quest 2 Controller Ring Shell Replacement, Remove the faceplate: 步骤 7 中的图像 1,3 Meta Quest 2 Controller Ring Shell Replacement, Remove the faceplate: 步骤 7 中的图像 2,3 Meta Quest 2 Controller Ring Shell Replacement, Remove the faceplate: 步骤 7 中的图像 3,3
      • Remove the controller faceplate.
      • The three friction pegs should hold the faceplate securely, so you don’t need to replace the adhesive during reassembly. Be sure to firmly press the faceplate onto the controller so that all friction pegs fully engage.
      询问修复机器人
      添加评论
    1. Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller ring shell: 步骤 8 中的图像 1,2 Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller ring shell: 步骤 8 中的图像 2,2
      • Use a Torx T5 driver to remove the four screws securing the controller ring shell to the controller:
      • Two 4.7 mm‑long screws
      • Two 5.9 mm‑long screws
      添加评论
    2. Meta Quest 2 Controller Ring Shell Replacement: 步骤 9 中的图像 1,2 Meta Quest 2 Controller Ring Shell Replacement: 步骤 9 中的图像 2,2
      • Press the point of a spudger firmly against the white alignment square to release the ring shell.
      询问修复机器人
      添加评论
    3. Meta Quest 2 Controller Ring Shell Replacement, Remove the controller ring shell: 步骤 10 中的图像 1,3 Meta Quest 2 Controller Ring Shell Replacement, Remove the controller ring shell: 步骤 10 中的图像 2,3 Meta Quest 2 Controller Ring Shell Replacement, Remove the controller ring shell: 步骤 10 中的图像 3,3
      • Use your fingers to grab the end of the ring shell that doesn’t have the white alignment square.
      • Gently lift the ring shell up and away from the controller to unclip it from the controller.
      • Remove the controller ring shell.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Arthur Shi
于01/03/18注册
344,571 声望
创作了915篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了42,768篇指南
1指南评论
This Tutorial was really fast and easy also, I fixed my controller and it works very well now, Thank you!
# “‪Diamond‬” # - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 49
过去 30 天: 185
总计 7,668
