跳转到主内容
加入维修社区 - 创建账户
Merch Source Projector Entertainment II Motherboard
你所需要的
  1. Merch Source Projector Entertainment II Motherboard, Outer Casing: 步骤 1 中的图像 1,2 Merch Source Projector Entertainment II Motherboard, Outer Casing: 步骤 1 中的图像 2,2
    • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
    询问修复机器人
    添加评论
  2. Merch Source Projector Entertainment II Motherboard: 步骤 2 中的图像 1,1
    • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
    • The bottom right panel screw does not come completely out the panel door.
    询问修复机器人
    添加评论
  3. Merch Source Projector Entertainment II Motherboard: 步骤 3 中的图像 1,2 Merch Source Projector Entertainment II Motherboard: 步骤 3 中的图像 2,2
    • Using your hands, gently pry the top and bottom of the projector casing apart.
    询问修复机器人
    添加评论
  4. Merch Source Projector Entertainment II Motherboard, Motherboard: 步骤 4 中的图像 1,2 Merch Source Projector Entertainment II Motherboard, Motherboard: 步骤 4 中的图像 2,2
    • Use the plastic opening tool to gently disengage the ribbon cable from its back housing.
    • Once the ribbon cable is disengaged gently pull the cable off the motherboard.
    • Once the housing is disengaged, the ribbon cable should slide out easy. Do not pull too hard on the ribbon cable as it is very fragile.
    询问修复机器人
    添加评论
  5. Merch Source Projector Entertainment II Motherboard: 步骤 5 中的图像 1,2 Merch Source Projector Entertainment II Motherboard: 步骤 5 中的图像 2,2
    • Unscrew the three 6 mm screws from the motherboard with the Phillips #0 screwdriver.
    • Be sure not to damage any of the wires atached to the motherboard.
    询问修复机器人
    添加评论
  6. Merch Source Projector Entertainment II Motherboard: 步骤 6 中的图像 1,2 Merch Source Projector Entertainment II Motherboard: 步骤 6 中的图像 2,2
    • Solder off all of the connections on the motherboard with a soldering iron.
    • Once connections are soldered off, the motherboard should be detached and ready for replacement.
    • Need some help? Follow this guide to learn soldering basics.
    • While soldering the metal connections can get very hot. Never touch the iron with your hand. also make sure that the projector is fully turned off and not plugged in.
    • If there is hot glue on top on the connection with the motherboard, you will need to peel it off using your fingers.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Michael Tan
于01/08/15注册
590 声望
创作了3篇指南
3指南评论
Was wondering if you could help me identify a microchip on the board by the speaker?
Brad Langland - 回复 分享
Where can I get parts for the projector? I think my board is cooked.
Delgtm - 回复 分享
mine acts like it does not recognize the rca cords. help
Kamela Mitchell - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 24
总计 2,379
