跳转到主内容
Macbook Pro 14" 2023 Speaker Assembly Replacement
你所需要的
  1. Macbook Pro 14" 2023 Speaker Assembly Replacement, Unfasten the lower case: 步骤 1 中的图像 1,2 Macbook Pro 14" 2023 Speaker Assembly Replacement, Unfasten the lower case: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    FixMat
    $36.95
    购买
    • Completely power off and unplug your MacBook Pro before you start. Close the screen and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove eight screws securing the lower case:
    • Four 9.3 mm screws
    • Four 5 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. Macbook Pro 14" 2023 Speaker Assembly Replacement, Unclip the lower case: 步骤 2 中的图像 1,2 Macbook Pro 14" 2023 Speaker Assembly Replacement, Unclip the lower case: 步骤 2 中的图像 2,2
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle to create a small gap under the lower case.
  3. Macbook Pro 14" 2023 Speaker Assembly Replacement, Release the right clips: 步骤 3 中的图像 1,3 Macbook Pro 14" 2023 Speaker Assembly Replacement, Release the right clips: 步骤 3 中的图像 2,3 Macbook Pro 14" 2023 Speaker Assembly Replacement, Release the right clips: 步骤 3 中的图像 3,3
    • Insert an opening pick into the gap you just created.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  4. Macbook Pro 14" 2023 Speaker Assembly Replacement, Release the left clips: 步骤 4 中的图像 1,3 Macbook Pro 14" 2023 Speaker Assembly Replacement, Release the left clips: 步骤 4 中的图像 2,3 Macbook Pro 14" 2023 Speaker Assembly Replacement, Release the left clips: 步骤 4 中的图像 3,3
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
  5. Macbook Pro 14" 2023 Speaker Assembly Replacement, Release the sliding clips: 步骤 5 中的图像 1,3 Macbook Pro 14" 2023 Speaker Assembly Replacement, Release the sliding clips: 步骤 5 中的图像 2,3 Macbook Pro 14" 2023 Speaker Assembly Replacement, Release the sliding clips: 步骤 5 中的图像 3,3
    • Sliding clips along the back edge of the MacBook further secure the lower case. Separating these clips may require a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Firmly pull the lower case away from the back edge, one corner at a time, to disengage the sliding clips.
    • Keep the lower case flat to the MacBook. Don't pull upward until it's completely separated.
  6. Macbook Pro 14" 2023 Speaker Assembly Replacement, Remove the lower case: 步骤 6 中的图像 1,3 Macbook Pro 14" 2023 Speaker Assembly Replacement, Remove the lower case: 步骤 6 中的图像 2,3 Macbook Pro 14" 2023 Speaker Assembly Replacement, Remove the lower case: 步骤 6 中的图像 3,3
    • Remove the lower case.
    • To reinstall the lower case:
    • Lay it down and align the sliding clips with the back edge of the MacBook. Press down on the lower case and slide it toward the back edge to engage the clips.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push.
    • Once the back corners of the lower case are secured and flush with the frame, press down along the middle of the lower case to engage the four remaining clips.
    • You'll hear and feel each clip snap into place.
  7. Macbook Pro 14" 2023 Speaker Assembly Replacement, Disconnect the battery board: 步骤 7 中的图像 1,3 Macbook Pro 14" 2023 Speaker Assembly Replacement, Disconnect the battery board: 步骤 7 中的图像 2,3 Macbook Pro 14" 2023 Speaker Assembly Replacement, Disconnect the battery board: 步骤 7 中的图像 3,3
    • Peel back any tape covering the battery board data cable connector on the logic board.
  8. Macbook Pro 14" 2023 Speaker Assembly Replacement: 步骤 8 中的图像 1,2 Macbook Pro 14" 2023 Speaker Assembly Replacement: 步骤 8 中的图像 2,2
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
  9. Macbook Pro 14" 2023 Speaker Assembly Replacement: 步骤 9 中的图像 1,2 Macbook Pro 14" 2023 Speaker Assembly Replacement: 步骤 9 中的图像 2,2
    • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
  10. Macbook Pro 14" 2023 Speaker Assembly Replacement, Unfasten the trackpad cable bracket: 步骤 10 中的图像 1,1
    • While your MacBook uses some Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to avoid stripping.
    • Use a T3 Torx driver to remove the two 2.1 mm‑long 3IP Torx Plus screws securing the trackpad cable bracket to the logic board.
  11. Macbook Pro 14" 2023 Speaker Assembly Replacement, Remove the trackpad cable bracket: 步骤 11 中的图像 1,2 Macbook Pro 14" 2023 Speaker Assembly Replacement, Remove the trackpad cable bracket: 步骤 11 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers, or your fingers, to remove the trackpad cable bracket.
  12. Macbook Pro 14" 2023 Speaker Assembly Replacement, Disconnect the trackpad cable: 步骤 12 中的图像 1,2 Macbook Pro 14" 2023 Speaker Assembly Replacement, Disconnect the trackpad cable: 步骤 12 中的图像 2,2
    • Use the flat end of a spudger to pry up and disconnect the trackpad cable's press connector secured to the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  13. Macbook Pro 14" 2023 Speaker Assembly Replacement, Reposition the trackpad cable: 步骤 13 中的图像 1,2 Macbook Pro 14" 2023 Speaker Assembly Replacement, Reposition the trackpad cable: 步骤 13 中的图像 2,2
    • The trackpad cable is lightly adhered to the frame.
    • Peel the trackpad cable away from the device, making sure to separate the adhesive.
  14. Macbook Pro 14" 2023 Speaker Assembly Replacement, Disconnect the battery board: 步骤 14 中的图像 1,2 Macbook Pro 14" 2023 Speaker Assembly Replacement, Disconnect the battery board: 步骤 14 中的图像 2,2
    • Peel back any tape covering the battery board data cable connector under the large pancake screw.
  15. Macbook Pro 14" 2023 Speaker Assembly Replacement: 步骤 15 中的图像 1,2 Macbook Pro 14" 2023 Speaker Assembly Replacement: 步骤 15 中的图像 2,2
  16. Macbook Pro 14" 2023 Speaker Assembly Replacement: 步骤 16 中的图像 1,2 Macbook Pro 14" 2023 Speaker Assembly Replacement: 步骤 16 中的图像 2,2
    • Disconnect the battery board data cable by sliding it out from its socket on the battery board.
  17. Macbook Pro 14" 2023 Speaker Assembly Replacement, Remove the data cable: 步骤 17 中的图像 1,2 Macbook Pro 14" 2023 Speaker Assembly Replacement, Remove the data cable: 步骤 17 中的图像 2,2
    • The battery board data cable is lightly adhered to the device.
    • Slide blunt nose tweezers under areas with adhesive to separate the cable from the device.
    • Remove the battery board data cable.
  18. Macbook Pro 14" 2023 Speaker Assembly Replacement, Unfasten the battery connector: 步骤 18 中的图像 1,1
    • Use a T5 Torx driver to remove the 3.8 mm 5IP Torx Plus wide-head screw securing the battery power connector.
  19. Macbook Pro 14" 2023 Speaker Assembly Replacement, Disconnect the battery connector: 步骤 19 中的图像 1,3 Macbook Pro 14" 2023 Speaker Assembly Replacement, Disconnect the battery connector: 步骤 19 中的图像 2,3 Macbook Pro 14" 2023 Speaker Assembly Replacement, Disconnect the battery connector: 步骤 19 中的图像 3,3
    • Use the flat end of your spudger to lift the battery connector away from the battery board, disconnecting the battery.
    • Lift the connector high enough that it doesn't accidentally make contact during the repair, but no more than 45 degrees to prevent damaging its hinge.
    • For added safety, place a barrier, such as a piece of a playing card, between the connector and board.
  20. Macbook Pro 14" 2023 Speaker Assembly Replacement, Disconnect the right speaker: 步骤 20 中的图像 1,2 Macbook Pro 14" 2023 Speaker Assembly Replacement, Disconnect the right speaker: 步骤 20 中的图像 2,2
    • Peel back the tape covering the right speaker ZIF connector.
  21. Macbook Pro 14" 2023 Speaker Assembly Replacement: 步骤 21 中的图像 1,2 Macbook Pro 14" 2023 Speaker Assembly Replacement: 步骤 21 中的图像 2,2
    • Use the pointed end of a spudger to gently pry up the locking flap on the right speaker ZIF connector.
  22. Macbook Pro 14" 2023 Speaker Assembly Replacement: 步骤 22 中的图像 1,2 Macbook Pro 14" 2023 Speaker Assembly Replacement: 步骤 22 中的图像 2,2
    • Disconnect the right speaker cable by sliding it out from its socket.
  23. Macbook Pro 14" 2023 Speaker Assembly Replacement, Disconnect the left speaker: 步骤 23 中的图像 1,3 Macbook Pro 14" 2023 Speaker Assembly Replacement, Disconnect the left speaker: 步骤 23 中的图像 2,3 Macbook Pro 14" 2023 Speaker Assembly Replacement, Disconnect the left speaker: 步骤 23 中的图像 3,3
    • Follow the procedure in the previous three steps to disconnect the left speaker.
  24. Macbook Pro 14" 2023 Speaker Assembly Replacement, Apply isopropyl alcohol: 步骤 24 中的图像 1,3 Macbook Pro 14" 2023 Speaker Assembly Replacement, Apply isopropyl alcohol: 步骤 24 中的图像 2,3 Macbook Pro 14" 2023 Speaker Assembly Replacement, Apply isopropyl alcohol: 步骤 24 中的图像 3,3
    • Apply a few drops of highly-concentrated isopropyl alcohol (>90%) in the gap between the speaker and the edge of the frame.
    • Wait for 1–2 minutes to allow time for the isopropyl alcohol to weaken the adhesive.
  25. Macbook Pro 14" 2023 Speaker Assembly Replacement, Separate the adhesive: 步骤 25 中的图像 1,3 Macbook Pro 14" 2023 Speaker Assembly Replacement, Separate the adhesive: 步骤 25 中的图像 2,3 Macbook Pro 14" 2023 Speaker Assembly Replacement, Separate the adhesive: 步骤 25 中的图像 3,3
    • Insert the tip of an opening pick in the gap between the speaker and the edge of the frame.
    • Slide the opening pick along the edge of the speaker to slice the adhesive beneath it.
  26. Macbook Pro 14" 2023 Speaker Assembly Replacement: 步骤 26 中的图像 1,2 Macbook Pro 14" 2023 Speaker Assembly Replacement: 步骤 26 中的图像 2,2
    • Insert the tip of an opening pick in the gap between the battery and the speaker.
    • Pry up with the pick to separate the speaker from the frame.
    • Take care not to puncture the battery while you pry. If you're having difficulty prying up, apply a few more drops of isopropyl alcohol.
  27. Macbook Pro 14" 2023 Speaker Assembly Replacement: 步骤 27 中的图像 1,2 Macbook Pro 14" 2023 Speaker Assembly Replacement: 步骤 27 中的图像 2,2
    • Slide the pick along the edge of the speaker to separate the adhesive.
  28. Macbook Pro 14" 2023 Speaker Assembly Replacement, Remove the speaker: 步骤 28 中的图像 1,3 Macbook Pro 14" 2023 Speaker Assembly Replacement, Remove the speaker: 步骤 28 中的图像 2,3 Macbook Pro 14" 2023 Speaker Assembly Replacement, Remove the speaker: 步骤 28 中的图像 3,3
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $5.99
    购买
    • Use your fingers to remove the speaker, making sure to peel off any remaining adhesive.
    • Repeat the loosening and separating process for the other speaker.
    • Use a pre-cut adhesive sheet, like Tesa Tape, to secure the speaker back to the frame.
    • Clean up any remaining adhesive from the frame before installing new adhesives.
结论
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 14" 2023 Answers community for help.
Chayton Ritter
于08/21/20注册
18,591 声望
创作了102篇指南
团队
Guide Team Guide Team 的会员
Staff
6 名成员
创作了7,844篇指南
2条评论
hey, i think the steps for unplugging the speakers are missing in this guide. it jumps from disconnecting the battery to removing the speaker without explaining which cable to unplug.
Jayce - 回复
Hi Jayce, good catch. I've updated the guide to show disconnecting the right and left speakers.
Chayton Ritter -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 46
总计 921
