跳转到主内容
MacBook Unibody Model A1278 Clutch Cover Replacement
Walter Galan
Walter Galan3 其他贡献者
最后更新于 February 1, 2017
没有估计
中等
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独使用。
This guide is an internal private guide that is used as a prereq.
  1. MacBook Unibody Model A1278 Clutch Cover Replacement, Clutch Cover: 步骤 1 中的图像 1,2 MacBook Unibody Model A1278 Clutch Cover Replacement, Clutch Cover: 步骤 1 中的图像 2,2
    • Slide the clutch cover toward the right edge of the display.
    • The clutch cover will move approximately .5" and stop. Do not force it too far to the right.
    • When reinstalling the clutch cover, be sure to slip it over the components protruding from the lower edge of the display about .25" to the right of its final installed position on the display.
  2. MacBook Unibody Model A1278 Clutch Cover Replacement: 步骤 2 中的图像 1,3 MacBook Unibody Model A1278 Clutch Cover Replacement: 步骤 2 中的图像 2,3 MacBook Unibody Model A1278 Clutch Cover Replacement: 步骤 2 中的图像 3,3
    • Starting at its far right end, rock the clutch cover along its long axis while pulling it away from the clutch hinge.
    • Working from right to left, carefully continue to release and lift the clutch along the lower edge of the display assembly.
    • Lift the clutch cover up off the front bezel and set it aside.
    • When reinstalling the clutch cover, be sure to widen the opening when slipping it over the small black plastic cosmetic cover that fills the open end of the clutch cover when it is in place. The cosmetic cover has very thin and delicate plastic arms that hold it to the right clutch hinge.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 17
总计 3,048
