跳转到主内容
加入维修社区 - 创建账户
MacBook Pro 17" Unibody Hard Drive Replacement
你所需要的
  1. MacBook Pro 17" Unibody Hard Drive Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Seven 3 mm Phillips screws.
    添加评论
  2. MacBook Pro 17" Unibody Hard Drive Replacement: 步骤 2 中的图像 1,2 MacBook Pro 17" Unibody Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
    • During reassembly, carefully align the lower case and then press it firmly until both clips engage.
    • Remove the lower case.
    添加评论
  3. MacBook Pro 17" Unibody Hard Drive Replacement, Battery: 步骤 3 中的图像 1,3 MacBook Pro 17" Unibody Hard Drive Replacement, Battery: 步骤 3 中的图像 2,3 MacBook Pro 17" Unibody Hard Drive Replacement, Battery: 步骤 3 中的图像 3,3
    • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
    • If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
    • If the plastic tab is missing, use a spudger to pry the connector up from its socket.
    • Pull the tab parallel to the face of the logic board.
    添加评论
  4. MacBook Pro 17" Unibody Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Remove the two Phillips screws securing the hard drive bracket to the upper case.
    • These screws are captive to the hard drive bracket.
    添加评论
  5. MacBook Pro 17" Unibody Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Remove the hard drive bracket from the upper case.
    询问修复机器人
    添加评论
  6. MacBook Pro 17" Unibody Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Use the hard drive's pull tab to lift it out of the upper case.
    • Don't try to completely remove the hard drive just yet! Its cable is still connected.
    询问修复机器人
    添加评论
  7. MacBook Pro 17" Unibody Hard Drive Replacement: 步骤 7 中的图像 1,2 MacBook Pro 17" Unibody Hard Drive Replacement: 步骤 7 中的图像 2,2
    • Pull the hard drive connector away from the body of the hard drive.
    • Remove the hard drive from your MacBook Pro.
    询问修复机器人
    添加评论
  8. MacBook Pro 17" Unibody Hard Drive Replacement, Hard Drive: 步骤 8 中的图像 1,2 MacBook Pro 17" Unibody Hard Drive Replacement, Hard Drive: 步骤 8 中的图像 2,2
    • Remove the four T6 Torx screws around the outer edge of the hard drive.
    • If desired, peel off the plastic pull tab and transfer it to your new hard drive.
    • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
    添加评论
结论
取消:我没有完成这个指南。
242等其他人完成本指南。
12指南评论
Very easy to follow. Replacing the HDD on these unibodies is super easy. Thanks for the guide.
tech4eleven - 回复 分享
Very easy, excepted for finding the right screw for Step 8. I replaced original HDD with a Samsung 840 EVO 500GB. Fine!
yello73 - 回复 分享
Exceptional instructions. If you're struggling to restore from a backup... connect your backup drive via cable, start your macbook, choose disk utilities, choose the new hard drive from the list on the left, if first aide options (repair/verify) are not available, erase and name the new drive, and then you should be able to restore from backup. :)
Deanna Ashby - 回复 分享
Thank goodness you posted this. I thought I messed up installation because there was no new HD when I turned on the laptop. I couldn't figure out how to restore. Then I saw this and tried it and it's restoring now. Thank you!!
catchpaco - 回复 分享
Very easy, Thank you for this tremendous guide. Works perfectly and I directly connected my old HDD to USB and restore all my information using the Migration Assistant app. Fine!
Abdullah Alqassar - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 49
过去 30 天: 262
总计 279,246
