简介
Use this guide to replace the battery in your MacBook Pro 16" late 2023 (M3 Pro/M3 Max).
The MacBook Pro uses stretch-release adhesives to secure the battery. Some of the strips are hidden underneath the trackpad, so you’ll need to remove it first to access the strips.
You'll need replacement battery adhesive in order to complete this repair.
Some photos in this guide are of the previous model MacBook Pro and may contain slight visual discrepancies, but they won't affect the procedure.
你所需要的
Fully shut down your MacBook, close the lid, and flip it over. Keep the lid closed until you've physically disconnected the battery.
Unplug the MagSafe cable and any accessories connected to your MacBook.
在这个步骤中使用的工具:FixMat$36.95
Use a P5 Pentalobe driver to remove eight screws securing the lower case:
Four 9.2 mm screws
Four 5 mm screws
Press a suction handle into place near the front edge of the lower case, between the screw holes.
Pull up on the suction handle to create a small gap under the lower case.
Insert an opening pick into the gap you just created.
Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
Repeat the previous step on the other side, using an opening pick to to release the second clip.
Firmly pull the lower case away from the back edge, one corner at a time, to disengage the sliding clips.
Remove the lower case.
Set it in place and align the sliding clips near the screen hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
Peel back any tape covering the battery board data cable connector on the logic board.
Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
Use a T3 Torx driver to remove the two 2.1 mm‑long screws securing the trackpad cable bracket to the logic board.
Use the flat end of a spudger to pry up and disconnect the trackpad cable's press connector from the logic board.
Peel the trackpad cable away from the device, making sure to separate the adhesive.
Peel back any tape covering the battery board data cable connector under the large pancake screw.
Slide blunt nose tweezers under areas with adhesive to separate the cable from the device.
Remove the battery board data cable.
Use a T5 Torx driver to remove the 4 mm pancake screw securing the battery power connector.
Use the flat end of your spudger to lift the battery connector away from the battery board, disconnecting the battery.
Use a T5 Torx driver to remove the 13 screws securing the trackpad assembly:
Ten 5 mm screws
Three 5.8 mm screws
Swing the display open slightly, but keep the MacBook upside-down. The trackpad assembly should separate and lay flat on the display.
Carefully feed the trackpad's ribbon cable through its slot in the frame.
Use a T5 Torx driver to remove the two screws securing the battery board:
One 4.5 mm screw
One 3.8 mm screw
There are eight adhesive strips that are accessed from the bottom of the device.
There are six more adhesive strips accessed from the trackpad's location on the frame.
Pull the strip out slowly and steadily at a low angle. Give it plenty of time to stretch and un-stick from under the battery.
If the adhesive strip breaks off, try to retrieve it using your fingers or blunt tweezers, and continue pulling—but do not pry under the battery.
Repeat the process for all 14 stretch release adhesive strips.
在这个步骤中使用的工具:Plastic Cards$2.99
Insert a plastic card between the battery and the frame.
Pry up with the card while slicing the adhesive to separate the battery from the frame.
在这个步骤中使用的工具:Stretch Release Battery Adhesive$3.99
Slide the battery toward the bottom of the MacBook and remove it.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 16" Late 2023 Answers community for help.
另外一个人完成了本指南。
