跳转到主内容
MacBook Pro 13" Unibody Mid 2009 Display Replacement
你所需要的
  1. MacBook Pro 13" Unibody Mid 2009 Display Replacement, Remove the lower case screws: 步骤 1 中的图像 1,1
    • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 13" Unibody Mid 2009 Display Replacement, Lift the lower case away: 步骤 2 中的图像 1,1
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. MacBook Pro 13" Unibody Mid 2009 Display Replacement, Battery: 步骤 3 中的图像 1,1
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
  4. MacBook Pro 13" Unibody Mid 2009 Display Replacement, Display: 步骤 4 中的图像 1,3 MacBook Pro 13" Unibody Mid 2009 Display Replacement, Display: 步骤 4 中的图像 2,3 MacBook Pro 13" Unibody Mid 2009 Display Replacement, Display: 步骤 4 中的图像 3,3
    • Use the flat end of a spudger to pry the subwoofer/right speaker cable connector up off its socket on the logic board.
    • Be very careful to pry under the connector as shown, and not under the socket itself. Otherwise you may accidentally separate the socket from the logic board.
  5. MacBook Pro 13" Unibody Mid 2009 Display Replacement: 步骤 5 中的图像 1,2 MacBook Pro 13" Unibody Mid 2009 Display Replacement: 步骤 5 中的图像 2,2
    • Disconnect the camera cable by sliding it horizontally out of its socket.
    • Pull the cable parallel to the surface of the logic board, in the direction of the optical drive. Do not pull straight up, or you will destroy the connector.
    • If you see a small plastic retainer stuck to the logic board that prevents the camera cable from sliding out, peel it up carefully from the logic board. Apply a little heat from a hair dryer or heat gun if necessary to help soften the adhesive holding it in place. Do not attempt to forcibly disconnect the cable with the retainer in place.
    • If you still have trouble, use the point of a spudger to push at each side of the connector and "walk" it slowly from its socket.
  6. MacBook Pro 13" Unibody Mid 2009 Display Replacement: 步骤 6 中的图像 1,1
    • De-route the camera data cable from the channel in the optical drive.
  7. MacBook Pro 13" Unibody Mid 2009 Display Replacement: 步骤 7 中的图像 1,2 MacBook Pro 13" Unibody Mid 2009 Display Replacement: 步骤 7 中的图像 2,2
    • Remove the following screws securing the camera data cable and right speaker to the upper case:
    • Two 8 mm Phillips screws.
    • One 4mm Phillips screw.
    • One of the 8 mm Phillips screws will likely remain captive in the camera cable ground loop.
    • Slide the camera cable bracket out from under the subwoofer and remove it from the computer.
  8. MacBook Pro 13" Unibody Mid 2009 Display Replacement: 步骤 8 中的图像 1,3 MacBook Pro 13" Unibody Mid 2009 Display Replacement: 步骤 8 中的图像 2,3 MacBook Pro 13" Unibody Mid 2009 Display Replacement: 步骤 8 中的图像 3,3
    • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-in side of the computer.
    • Pull the display data cable connector straight away from its socket.
    • Make sure to pull the connector straight away and not straight up from its socket.
  9. MacBook Pro 13" Unibody Mid 2009 Display Replacement: 步骤 9 中的图像 1,2 MacBook Pro 13" Unibody Mid 2009 Display Replacement: 步骤 9 中的图像 2,2
    • Remove the following two screws securing the display data cable bracket to the upper case:
    • One 7 mm Phillips screw.
    • One 5 mm Phillips screw.
    • Lift the display data cable bracket out of the upper case.
  10. MacBook Pro 13" Unibody Mid 2009 Display Replacement: 步骤 10 中的图像 1,2 MacBook Pro 13" Unibody Mid 2009 Display Replacement: 步骤 10 中的图像 2,2
    • Remove the two outer 6.5 mm Torx screws securing each of the two display brackets to the upper case (4 screws total).
  11. MacBook Pro 13" Unibody Mid 2009 Display Replacement: 步骤 11 中的图像 1,1
    • Open your MacBook so the display is perpendicular to the upper case.
    • Place your opened MacBook on a table as pictured.
    • While holding the display and upper case together with your left hand, remove the remaining 6.5 mm Torx screw from the lower display bracket.
  12. MacBook Pro 13" Unibody Mid 2009 Display Replacement: 步骤 12 中的图像 1,1
    • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
    • Remove the last remaining 6 mm T6 Torx screw securing the display to the upper case.
  13. MacBook Pro 13" Unibody Mid 2009 Display Replacement: 步骤 13 中的图像 1,2 MacBook Pro 13" Unibody Mid 2009 Display Replacement: 步骤 13 中的图像 2,2
    • Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
    • Rotate the display slightly away from the upper case.
  14. MacBook Pro 13" Unibody Mid 2009 Display Replacement: 步骤 14 中的图像 1,1
    • Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
结论
63等其他人完成本指南。
一条评论
Does the same apply to the 2009 and 2010 15”?
IFCJW - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 25
过去 30 天: 103
总计 93,282
