替换MacBook Pro 13‘’2016年末期带功能键版本的电池
简介
转到步骤 1用这条指南来安全地用iFixit更换电池工具从你那MacBook Pro上拆除满是胶的电池。你的iFixit工具中的除胶剂可以溶化固定电池的胶,让你轻而易举地拆除电池。
“iFixit除胶剂非常易燃。”请在通风良好的地区做这件工作。在此过程中不要吸烟或是靠近明火。
注意:用来溶解胶的溶剂会损伤某些塑料。遵照所有这些指导并在涂溶剂的时候多加小心。
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
查看更多...
准备一个iOpener,把它放在触摸板排线上持续大概一分钟,来软化把触控板排线黏在电池上的双面胶。
如果你没有iOpener,可以用一台吹风机来加热排线。排线应该是热的,但不能热到没法碰。千万小心不要使电池过热。
要重新组装你的设备,请按逆序操作。
要重新组装你的设备,请按逆序操作。
88等其他人完成本指南。
由衷感谢以下译者:
95%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
29指南评论
Does the replacement battery comes with the same strong adhesive as the original battery?
I ordered my battery for the 2017 version of the Macbook Pro with function keys from ebay and it didn’t came with a adhesive strip. I am sure you can use your own adhesive strips or double sided tape, as long as you mind the gabs on the aluminum frame,
Serj Nko -
Hi Jeff,
Thank you for this great work to beat Apple greediness. I followed the exact steps and everything went well, but my battery is not charging nor the status is shown on the bar! I tried restarting and resetting and even restoring and it did not work would that be something you can help me with?
If the old battery still works, try putting it back in, and see if that clears up the problem. If it does, the new battery is defective.
