简介
使用本指南升级或更换MacBook Pro 13“2013年末的固态硬盘。此MacBook Pro使用的是Apple独占的SSD插槽,因此,在没有使用适配器的情况下,无法使用普通的M.2驱动器。
当你在进行这项维修之前,尽可能的备份你的SSD。然后按照你熟悉的方式,从网络恢复系统或者创建一个启动驱动器,这样你就会在新的SSD上安装macOS,并且迁移旧的SSD上的数据。
最后,我们强烈建议在从MacBook Pro更换原始SSD之前安装macOS 10.13 High Sierra(或更高版本的macOS)。 大多数新款的SSD需要高版本的系统提供的驱动程序。
你所需要的
拆下以下10个固定在上壳体上的螺丝
两个 2.3毫米 的梅花五角螺丝
八个 3.0毫米 的梅花五角螺丝
按照本指南的相反步骤来重新组装您的设备。
149等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
22条评论
So… can I just buy the new PCIe SSDs and use it in the 2013 rMBP? I'm very confused about these PCIe SSDs.
My retina 15" got the logic board damage and fix it is just stupid. Now in the mean time the new ones come up next quarter, I'm using my macbook pro 2011. Now, because the 2011 is no Retina, SSD and all the other good stuff in it (crying in silence) I did some research to make the 2011 better and I found out I can upgrade to 16 ram and a SSD. Now I check and is not that expensive at least for a SSD 128. BUT this morning it hit me, and I want to ask and make research about this idea. Guys I was wondering, can I take the SSD from my Retina that is actually SSD 256 and put it in my 2011? And save in the SSD? I mean, if possible of curse, if not I would go to buy it how I plan in the first place. Anyway guys any suggestions, ideas or advice are all welcome. I want to know whats best to improve the 2011 meanwhile the new ones get the upgrade. Thanks in advance! :)
Can I use an Intel SSD 540s SSD M.2? Intel says it doesn't support NVMe. Does it need to or would that just add extra performance?
You can put an NVMe drive (with an adapter) in a late 2013 MBP, but you must have updated the OS to the latest version because the original, native OS does not support NVMe. Use Clonezilla to make a bare metal backup and use Clonezilla to restore it once NVMe is installed. Clonezilla wont work going down in size ie from a 1TB to 500GB drive.
Can you also please put a link how to reinstall mac os after installing a new hardrive? thanks
