跳转到主内容
加入维修社区 - 创建账户
MacBook Air 13" Early 2015 Display Assembly Replacement
你所需要的
视频概述
    1. MacBook Air 13" Early 2015 Display Assembly Replacement, Lower Case: 步骤 1 中的图像 1,1
      在这个步骤中使用的工具:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
      • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
      • Two 9 mm screws
      • Eight 2.6 mm screws
      添加评论
    2. MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 2 中的图像 1,1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      添加评论
    1. MacBook Air 13" Early 2015 Display Assembly Replacement, Battery Connector: 步骤 3 中的图像 1,2 MacBook Air 13" Early 2015 Display Assembly Replacement, Battery Connector: 步骤 3 中的图像 2,2
      • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
      • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
      • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
      添加评论
    1. MacBook Air 13" Early 2015 Display Assembly Replacement, I/O Board Cable: 步骤 4 中的图像 1,1
      • Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
      添加评论
    2. MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 5 中的图像 1,1
      • Carefully peel the I/O board cable from the adhesive securing it to the top of the fan.
      • During reassembly, make sure this cable is in the correct orientation. It will fit if reversed, but the laptop will not boot.
      添加评论
    3. MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 6 中的图像 1,2 MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 6 中的图像 2,2
      • The following connector has an especially deep socket. Use care when disconnecting it.
      • While gently pulling the I/O board cable upward near its connection to the logic board, use the flat end of a spudger to pry up on alternating sides of the connector to help "walk" it out of its socket.
      • Remove the I/O board cable.
      添加评论
    1. MacBook Air 13" Early 2015 Display Assembly Replacement, Fan: 步骤 7 中的图像 1,1
      • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap, not the socket itself.
      添加评论
    2. MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 8 中的图像 1,1
      • Peel the rubber gasket off the adhesive on the top of the fan.
      添加评论
    3. MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 9 中的图像 1,1
      • Remove the following three screws securing the fan to the upper case:
      • One 5.2 mm T5 Torx screw
      • One 3.3 mm T5 Torx screw
      • One 4.4 mm T5 Torx screw with a short head
      添加评论
    4. MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 10 中的图像 1,2 MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 10 中的图像 2,2
      • Lift the fan from the I/O board side and pull it free from the upper case.
      • Removing the fan will also disconnect the fan ribbon cable. Be careful not to snag it.
      添加评论
    1. MacBook Air 13" Early 2015 Display Assembly Replacement, I/O Board: 步骤 11 中的图像 1,1
      • Disconnect the I/O board by pulling its power cable away from its socket on the logic board.
      • Pull the cable parallel to the face of the logic board toward the right edge of the Air.
      添加评论
    2. MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 12 中的图像 1,2 MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 12 中的图像 2,2
      • Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
      • Pry up from beneath the wires.
      添加评论
    3. MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 13 中的图像 1,2 MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 13 中的图像 2,2
      • Use the tip of a spudger to carefully flip up the retaining flap on the microphone ribbon cable ZIF socket.
      • Make sure you are flipping up the retaining flap, not the socket itself.
      添加评论
    4. MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 14 中的图像 1,1
      • Remove the single 4.1 mm T5 Torx screw securing the I/O board to the upper case.
      添加评论
    5. MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 15 中的图像 1,2 MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 15 中的图像 2,2
      • Gently de-route the camera cable from its notch on the I/O board and push it out of the way with the tip of a spudger.
      添加评论
    6. MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 16 中的图像 1,1
      • Lift the I/O board from the logic board side and pull it free from the upper case.
      • Removing the I/O board will also disconnect the microphone ribbon cable. Be careful not to snag it.
      添加评论
    1. MacBook Air 13" Early 2015 Display Assembly Replacement, Display Assembly: 步骤 17 中的图像 1,2 MacBook Air 13" Early 2015 Display Assembly Replacement, Display Assembly: 步骤 17 中的图像 2,2
      • Use the flat end of a spudger to pry each of the antenna connectors up from their sockets on the AirPort/Bluetooth card.
      添加评论
    2. MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 18 中的图像 1,2 MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 18 中的图像 2,2
      • Disconnect the camera cable connector with the tip of a spudger.
      • Push first on one side of the connector, then on the other side to carefully "walk" it out of its socket.
      • Pull the camera cable parallel to the face of the I/O board toward the front edge of the Air to disconnect it from its socket.
      • Do not lift upward on this cable as you disconnect it, as its socket may break off the logic board.
      添加评论
    3. MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 19 中的图像 1,2 MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 19 中的图像 2,2
      • Pull the plastic tab on the display data cable connector to unlock it.
      询问修复机器人
      添加评论
    4. MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 20 中的图像 1,2 MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 20 中的图像 2,2
      • Pull the display data cable connector straight out of its socket.
      • Make sure to pull the connector parallel to the logic board, do not lift straight up from its socket.
      添加评论
    5. MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 21 中的图像 1,2 MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 21 中的图像 2,2
      • Remove the inner four (two on each side) 5.6 mm T8 Torx screws securing the right and left display hinges to the upper case.
      • Leaving the outer screws in place for now will aid in disassembly.
      添加评论
    6. MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 22 中的图像 1,1
      • Gently de-route the antenna cables out of the channel cut into the upper case.
      添加评论
    7. MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 23 中的图像 1,1
      • Open the display so that it is perpendicular to the upper case and place it on a table as shown.
      询问修复机器人
      添加评论
    8. MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 24 中的图像 1,1
      • While holding the Air steady, remove the remaining 5.6 mm T8 Torx screw from the left display bracket.
      询问修复机器人
      添加评论
    9. MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 25 中的图像 1,1
      • Turn the computer onto its opposite edge so the right display screw is now easily accessible.
      • Before removing the last display screw, be sure to hold the display and upper case steady with your other hand. Failure to do so may allow the components to fall onto the table, causing potentially expensive damage.
      • Remove the last 5.6 mm T8 Torx screw securing the display to the upper case.
      询问修复机器人
      添加评论
    10. MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 26 中的图像 1,3 MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 26 中的图像 2,3 MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 26 中的图像 3,3
      • Open the Air slightly to allow room for the hinges to slide out of their notches.
      • Push the upper case slightly toward the display assembly, then push it back from the hinges.
      • Once the two display hinges have cleared the upper case, remove the display and set it aside.
      询问修复机器人
      添加评论
    11. MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 27 中的图像 1,2 MacBook Air 13" Early 2015 Display Assembly Replacement: 步骤 27 中的图像 2,2
      • During reassembly, use the flat end of a spudger to tuck the Wi-Fi/Bluetooth antenna back into its channel.
      添加评论
结论
取消:我没有完成这个指南。
122等其他人完成本指南。
iRobot
于09/24/09注册
1 声望
创作了636篇指南
34指南评论
Followed this guide to replace a broken display assembly on my Macbook Air. Complete everything in 40 minutes with little problem. My only problem was ripping the tab off the microphone ribbon cable which made this part a little bit more difficult, but didn't end up being a huge deal.
Nathan McAuley - 回复 分享
Would you be able to replace the screen with a 13" macbook pro retina screen on the newest 2015 13" Macbook Air?
Nate - 回复 分享
Not even close.
maccentric - 回复 分享
For people who need context with their answers rather than just receiving an ambiguous NO:
The screens from the MacBook Air models and the regular MacBook & MacBook Pro are NOT INTERCHANGEABLE BECAUSE:
they have different connectors. The air has 13 pins and the MacBooks have 20 pins.
(I think that is correct, might be 21 pins)
there is no realistic way to alter the hardware of device.
You would have to use some ritual magic and tweaker math.
We are talking about swapping different architectures in this scenario, so beyond that maybe there is a bridging connector but I would imagine that you would have to install some kind of accelerator to compensate for the difference and render the display properly.
However, on a lighter note:
•2010-2017 Airs have compatible LCDs 11 and 13 inch can be swapped for testing purposes.
•2013-2017 Airs are fully compatible.
•2010-2011 11" Airs have a shorter WIFI cable. •2012 is usable on 2010-2012.
LD GROUP - 回复 分享
Excellent - just replaced a display. It's easier to reattach the ribbon cables for the mic and fan before putting I/O board and fan back in - that's the only suggestion I have.
cskellum4 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 111
过去 30 天: 350
总计 171,982
