跳转到主内容
MacBook Air 13" Early 2014 Solid-State Drive Replacement
你所需要的
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  1. MacBook Air 13" Early 2014 Solid-State Drive Replacement: 步骤 2 中的图像 1,1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  2. MacBook Air 13" Early 2014 Solid-State Drive Replacement, Battery Connector: 步骤 3 中的图像 1,2 MacBook Air 13" Early 2014 Solid-State Drive Replacement, Battery Connector: 步骤 3 中的图像 2,2
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  3. MacBook Air 13" Early 2014 Solid-State Drive Replacement, Solid-State Drive: 步骤 4 中的图像 1,1
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  4. MacBook Air 13" Early 2014 Solid-State Drive Replacement: 步骤 5 中的图像 1,2 MacBook Air 13" Early 2014 Solid-State Drive Replacement: 步骤 5 中的图像 2,2
    • Gently lift the end of the SSD about half an inch and pull it straight out of its socket on the logic board.
    • Don't lift the SSD more than half an inch—doing so may damage the SSD or its socket on the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
结论
85等其他人完成本指南。
Jeff Suovanen
于08/06/13注册
405,334 声望
创作了258篇指南
团队
iFixit iFixit 的会员
Community
140 名成员
创作了16,871篇指南
23条评论
Fairly straight forward once you get the right screwdrivers. Took me less than 10 minutes.
Jesse Collis - 回复
Very simple and straight forward replacement. First-party SSD replacement can be found on ebay (typically removed from parted-out MacBook Airs). Currently they're aren't any third-party parts available.
rickhendricks - 回复
Don't forget to re-attach the battery cable before closing up the underside... not that I did or anything ;-/
phil - 回复
The Relevant Parts list all has incorrect links. Bait & Switch??
Examples:
"$199.95 Macbook Air 11" and 13" (Mid 2013/Early 2014) SSD, 256 GB"
Actually supplies: 128GB USED
"$349.95 Macbook Air 11" and 13" (Mid 2013/Early 2014) SSD, 512 GB"
Actually supplies: 256GB USED
carnthehawks - 回复
Whoops! Looks like we didn't update the details on those parts when we updated the part itself, sorry about that!
Sam Goldheart -
添加评论
浏览统计数据:
过去 24 小时: 38
过去 7 天: 301
过去 30 天: 1,347
总计 269,268
