跳转到主内容
加入维修社区 - 创建账户
MacBook Air 11" Mid 2011 Trackpad Replacement
你所需要的
  1. MacBook Air 11" Mid 2011 Trackpad Replacement, Lower Case: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
    添加评论
  2. MacBook Air 11" Mid 2011 Trackpad Replacement: 步骤 2 中的图像 1,1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    添加评论
  3. MacBook Air 11" Mid 2011 Trackpad Replacement, Battery: 步骤 3 中的图像 1,2 MacBook Air 11" Mid 2011 Trackpad Replacement, Battery: 步骤 3 中的图像 2,2
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
    添加评论
  4. MacBook Air 11" Mid 2011 Trackpad Replacement: 步骤 4 中的图像 1,1
    • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
    添加评论
  5. MacBook Air 11" Mid 2011 Trackpad Replacement: 步骤 5 中的图像 1,1
    • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
    添加评论
  6. MacBook Air 11" Mid 2011 Trackpad Replacement, Trackpad: 步骤 6 中的图像 1,2 MacBook Air 11" Mid 2011 Trackpad Replacement, Trackpad: 步骤 6 中的图像 2,2
    • Use the point of a spudger to lift the ZIF connector retaining flap on the trackpad data cable.
    • Gently slide the ribbon cable out of the ZIF connector.
    • Adjust, but do not remove the T5 Trackpad Sensitivity Screw to change the trackpad's depth sensitivity.
    添加评论
  7. MacBook Air 11" Mid 2011 Trackpad Replacement: 步骤 7 中的图像 1,3 MacBook Air 11" Mid 2011 Trackpad Replacement: 步骤 7 中的图像 2,3 MacBook Air 11" Mid 2011 Trackpad Replacement: 步骤 7 中的图像 3,3
    • With one hand, push the keyboard ribbon cable in slightly to access the ZIF connector beneath it.
    • Use a spudger to flip up the retaining flap.
    • Gently slide the cable out of the connector.
    添加评论
  8. MacBook Air 11" Mid 2011 Trackpad Replacement: 步骤 8 中的图像 1,1
    • Remove the six 1.5 mm Phillips #00 screws holding the trackpad in place.
    • These screws are installed tightly and strip easily. Be careful as you remove them.
    添加评论
  9. MacBook Air 11" Mid 2011 Trackpad Replacement: 步骤 9 中的图像 1,3 MacBook Air 11" Mid 2011 Trackpad Replacement: 步骤 9 中的图像 2,3 MacBook Air 11" Mid 2011 Trackpad Replacement: 步骤 9 中的图像 3,3
    • Open the device about 10 degrees.
    • While holding the bottom of the trackpad, press up on the side of the trackpad closest to the logic board to free it from the upper case.
    • Remove the trackpad from the device.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
29等其他人完成本指南。
Brett Hartt
于04/12/10注册
132,207 声望
创作了144篇指南
团队
iFixit iFixit 的会员
Staff
122 名成员
创作了26,617篇指南
7指南评论
Bought a T5 screwdriver. Screws on my Macbook Air late 2011 won't turn. I thought one was unscrewing but as it turned out, I was just destroying the screw so it is now stuck forever and I'll never be able to open this thing. Great, I really do have an aluminium pile of trash now.
Andy Barratt - 回复 分享
In the tools list is missing the screwdriver Philips #00
John - 回复 分享
Thanks! Updated.
Andrew Optimus Goldheart - 回复 分享
Please remove this guide. It has errors that cause me to strip one of my track pad screws. (Good otherwise and thanks for writing it.)
There is an almost identical guide MacBook Air 13" Mid 2011 Trackpad Replacement
that list the correct screw size #000 for the track pad and also shows the correct battery connector for my 2011 13" MacBook Air.
julie - 回复 分享
The case screws are P5 pentalobe and not torx T5. The battery screws are torx T5.
julie - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 97
总计 36,425
