当前版本的文档还未经巡查,您可以查看最新的已查核版本。
简介
使用本指南可升级或更换 MacBook Air 11" Early 2014 中的固态硬盘。此款 MacBook Air 使用 专有存储驱动器接口,因此在不使用适配器的情况下与普通 M.2 硬盘不兼容。
在执行此维修之前,如果可能的话,请备份现有的固态硬盘。然后,熟悉在线备份或创建可启动的外部驱动器,这样你就可以将 macOS 安装到新硬盘上,并将数据迁移到新的固态硬盘上。
最后,我们强烈建议你在更换 MacBook Air 上原有的固态硬盘之前,先安装 macOS 10.13 High Sierra(或更高版本的 macOS)。大多数新固态硬盘都需要更新存储驱动程序,而在 High Sierra 之前的 macOS 版本中找不到这些驱动程序。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
要重新组装设备,请按照相反的说明进行操作。
47等其他人完成本指南。
由衷感谢以下译者:
100%
Yanqi Wang正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
7条评论
can I use my HD SSD from MB Air 2011MID / 13" to this one, EARLY2014 / 11" ??
gustyn2000 - 回复
Agree with Daniel on OS installation and transfer of files from old disk. This last step needs to be in this guide for sure, otherwise it is an incomplete fix.
Z
The repair itself went smoothly; the advice to make sure the replacement SSD was properly seated was appropriate.
However, the essential step of transferring the OS from backup was challenging. The replacement SSD (OWC Aura Pro) requires that the computer run High Sierra (macOS 10.13) because of needed firmware, but my computer was running Sierra (macOS 10.12). I installed 10.13 on the SSD that I was about to replace, but this was not sufficient. The replacement SSD was not recognized. The backup from which the system is to be restored also has to run 10.13. I resolved this impasse by booting the computer in target disk mode with a new machine that is running 10.13 and cloning the system from that machine.
The instructions that came with the OWC Aura Pro SSD say, “MacOS 10.13 High Sierra … must be installed on the host computer before installing the OWC Aura Pro SSD.“ This information, along with the fact that the backup must also run High Sierra, should be on this website.
excellent set of instructions. thank u
