跳转到主内容
MacBook Air 11" Mid 2013 SSD Replacement
你所需要的
  1. MacBook Air 11" Mid 2013 SSD Replacement, Lower Case: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    购买
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Mid 2013 SSD Replacement: 步骤 2 中的图像 1,1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Mid 2013 SSD Replacement, Battery Connector: 步骤 3 中的图像 1,2 MacBook Air 11" Mid 2013 SSD Replacement, Battery Connector: 步骤 3 中的图像 2,2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
  4. MacBook Air 11" Mid 2013 SSD Replacement, SSD: 步骤 4 中的图像 1,1
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  5. MacBook Air 11" Mid 2013 SSD Replacement: 步骤 5 中的图像 1,3 MacBook Air 11" Mid 2013 SSD Replacement: 步骤 5 中的图像 2,3 MacBook Air 11" Mid 2013 SSD Replacement: 步骤 5 中的图像 3,3
    • Lift the free end of the SSD just enough to get a good hold of it.
    • Do not excessively lift the end of the SSD.
    • Pull the drive straight out of its socket and remove it from the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
结论
52等其他人完成本指南。
Sam Goldheart
于10/18/12注册
466,147 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,410篇指南
15条评论
Is it possible to replace a 128 GB SSD with a 256 GB SSD without any problems?
Roland - 回复
Anyone knows if you can replace the msata ssd or if it is proprietary of apple?
Felipe - 回复
I wonder if someone can help me - I completed the installation and rebooted from a clone of the original drive on an external USB disk. I tried to clone that back onto the new SSD but that failed and now the new SSD does not appear on the desktop and does not appear in Disk Utility. Its not being recognised when I boot up. Do you have any ideas how I can get it to reappear - I assume the format is lost so is there a way to reformat?
brendanorourke - 回复
Can i upgrade my ssd drive from 128 to 1TB ?
mohd.a2017 - 回复
i want to know too
pulido_066 -
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 31
过去 30 天: 215
总计 75,009
