跳转到主内容
Mac Mini Mid 2010 Cowling Replacement
Andrew Bookholt
Andrew Bookholt3 其他贡献者
最后更新于 December 27, 2022
没有估计
中等
Use this guide to remove the small molded plastic cowl used to direct cool air toward the heat sink.
  1. Mac Mini Mid 2010 Cowling Replacement, Bottom Cover: 步骤 1 中的图像 1,2 Mac Mini Mid 2010 Cowling Replacement, Bottom Cover: 步骤 1 中的图像 2,2
    • Place your thumbs in the depressions cut into the bottom cover.
    • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
  2. Mac Mini Mid 2010 Cowling Replacement: 步骤 2 中的图像 1,1
    • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
    • Remove the bottom cover and set it aside.
  3. Mac Mini Mid 2010 Cowling Replacement, Fan: 步骤 3 中的图像 1,1
    • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
  4. Mac Mini Mid 2010 Cowling Replacement: 步骤 4 中的图像 1,1
    • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
    • If the fan doesn't separate from the standoff screw with a moderate amount of force, you can use a T6 Torx driver to simply remove this screw.
  5. Mac Mini Mid 2010 Cowling Replacement: 步骤 5 中的图像 1,1
    • Lift the fan out of the mini for enough clearance to access its connector.
    • Carefully pull the fan cables upward to lift the fan connector up out of its socket on the logic board.
    • Remove the fan.
  6. Mac Mini Mid 2010 Cowling Replacement, Cowling: 步骤 6 中的图像 1,1
    • Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
  7. Mac Mini Mid 2010 Cowling Replacement: 步骤 7 中的图像 1,1
    • Lift the cowling from the end nearest the antenna plate.
    • Rotate the cowling away from the outer case and remove it from the mini.
结论
6等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 29
总计 7,366
