跳转到主内容
加入维修社区 - 创建账户
MNT Reform CPU Module Replacement
你所需要的
  1. MNT Reform CPU Module Replacement, Remove Bottom Plate Screws: 步骤 1 中的图像 1,1
    • Remove the following screws securing the transparent acrylic bottom plate to the main box:
    • Ten M2×6mm silver Phillips screws
    询问修复机器人
    添加评论
  2. MNT Reform CPU Module Replacement, Remove Bottom Plate: 步骤 2 中的图像 1,1
    • Lift the bottom plate and set it aside.
    • Before servicing anything on the inside, make sure to remove all battery cells.
    询问修复机器人
    添加评论
  3. MNT Reform CPU Module Replacement, Remove Battery Cells: 步骤 3 中的图像 1,2 MNT Reform CPU Module Replacement, Remove Battery Cells: 步骤 3 中的图像 2,2
    • Pull out the eight battery cells one by one, and set them aside safely.
    • Do not use a metal tool to remove the batteries. You may accidentally short-circuit the metal pins of the battery holders.
    • When replacing the batteries, pay attention to the polarity! Inserting a cell the wrong way in will damage your device.
    • The circuit board indicates the + and - orientation for each cell.
    询问修复机器人
    添加评论
  4. MNT Reform CPU Module Replacement, Remove Heatsink Screws: 步骤 4 中的图像 1,1
    • Remove the following screws securing the heatsink:
    • Four M2×12 Philips screws
    询问修复机器人
    添加评论
  5. MNT Reform CPU Module Replacement, Remove the Heatsink: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Gently pull the heatsink up.
    • Take care not to lose the four cylindrical plastic spacers supporting the heatsink.
    • When replacing the heatsink, remember to place the spacers over the screw holes before screwing down the heatsink. It may be helpful to use tweezers to align the spacers if placing the heatsink on top shifted them.
    • When replacing the heatsink into the laptop, you will need to apply new thermal paste. We have a thermal paste guide that makes replacing the thermal compound easy.
    • If you need to remove the heatsink frequently, it is possible to replace the thermal paste with a 0.5mm thermal pad instead.
    询问修复机器人
    添加评论
  6. MNT Reform CPU Module Replacement, Disconnect CPU Module Ribbon Cable: 步骤 6 中的图像 1,2 MNT Reform CPU Module Replacement, Disconnect CPU Module Ribbon Cable: 步骤 6 中的图像 2,2
    • Gently lift the black tab on the ribbon cable connector, then slide the ribbon cable out.
    询问修复机器人
    添加评论
  7. MNT Reform CPU Module Replacement, Release CPU Module: 步骤 7 中的图像 1,1
    • Release the tabs on each side of the CPU module by pulling them at the same time.
    • These tabs lock the module in place and releasing them will cause the module to "pop" up, similarly to a RAM stick on other laptop computers.
    询问修复机器人
    添加评论
  8. MNT Reform CPU Module Replacement, Remove CPU Module: 步骤 8 中的图像 1,1
    • Pull the CPU module out of its socket on the motherboard.
    • To avoid damaging its socket on the motherboard, do not excessively lift the free end of the CPU module.
    询问修复机器人
    添加评论
结论
To reassemble your device, follow these instructions in reverse order. Don't forget to re-apply new thermal paste.
Ensure that no cables are squeezed when replacing the bottom plate. Don’t overtighten screws.
取消:我没有完成这个指南。
另外一个人完成了本指南。
Neelfyn
于05/13/14注册
981 声望
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 20
总计 937
