跳转到主内容
加入维修社区 - 创建账户
Logitech G X56 HOTAS Throttle LED Board Replacement
你所需要的
  1. Logitech G X56 HOTAS Throttle LED Board Replacement, Label Plate: 步骤 1 中的图像 1,2 Logitech G X56 HOTAS Throttle LED Board Replacement, Label Plate: 步骤 1 中的图像 2,2
    • Remove the eight 8.6 mm long 1.5 mm hex screws from the label plate.
    询问修复机器人
    添加评论
  2. Logitech G X56 HOTAS Throttle LED Board Replacement: 步骤 2 中的图像 1,1
    • Use an opening tool to pry off the mode switch knob.
    询问修复机器人
    添加评论
  3. Logitech G X56 HOTAS Throttle LED Board Replacement: 步骤 3 中的图像 1,3 Logitech G X56 HOTAS Throttle LED Board Replacement: 步骤 3 中的图像 2,3 Logitech G X56 HOTAS Throttle LED Board Replacement: 步骤 3 中的图像 3,3
    • Remove the eight 12.5 mm long Phillips #1 screws from the underside of the label plate.
    • These screws are plastic! Be very careful when applying force.
    询问修复机器人
    添加评论
  4. Logitech G X56 HOTAS Throttle LED Board Replacement: 步骤 4 中的图像 1,2 Logitech G X56 HOTAS Throttle LED Board Replacement: 步骤 4 中的图像 2,2
    • Place the throttle right side up again, using the bottom panel as a coaster.
    • Gently pry the label plate from the body of the throttle.
    询问修复机器人
    添加评论
  5. Logitech G X56 HOTAS Throttle LED Board Replacement, Motherboard: 步骤 5 中的图像 1,2 Logitech G X56 HOTAS Throttle LED Board Replacement, Motherboard: 步骤 5 中的图像 2,2
    • Optional: Take a picture or mark each connector as you remove them for ease of reassembly.
    • Disconnect all of the motherboard connectors by pulling them straight up and out of their sockets.
    询问修复机器人
    添加评论
  6. Logitech G X56 HOTAS Throttle LED Board Replacement: 步骤 6 中的图像 1,2 Logitech G X56 HOTAS Throttle LED Board Replacement: 步骤 6 中的图像 2,2
    • Remove the four 11.6 mm-long Phillips #0 screws that secure the motherboard.
    询问修复机器人
    添加评论
  7. Logitech G X56 HOTAS Throttle LED Board Replacement: 步骤 7 中的图像 1,1
    • Lift the motherboard from the base plate shell, carefully making sure to keep the USB power cable unstrained.
    询问修复机器人
    添加评论
  8. Logitech G X56 HOTAS Throttle LED Board Replacement, LED Board: 步骤 8 中的图像 1,2 Logitech G X56 HOTAS Throttle LED Board Replacement, LED Board: 步骤 8 中的图像 2,2
    • Each LED Board uses the LEDs to hold it against the base plate. It also has a single cable set to the logic and power board.
    询问修复机器人
    添加评论
  9. Logitech G X56 HOTAS Throttle LED Board Replacement: 步骤 9 中的图像 1,2 Logitech G X56 HOTAS Throttle LED Board Replacement: 步骤 9 中的图像 2,2
    • Each of the LEDs needs to be removed with a soldering iron and your choice of solder wick or solder sucker.
    • Once free of the solder, the LED must be pushed through to the front.
    询问修复机器人
    添加评论
  10. Logitech G X56 HOTAS Throttle LED Board Replacement: 步骤 10 中的图像 1,1
    • Gently Remove the LED board.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 30
总计 339
