跳转到主内容
Logitech G Pro X Superlight Battery Replacement
你所需要的
  1. Logitech G Pro X Superlight Battery Replacement, Prepare your mouse for disassembly: 步骤 1 中的图像 1,3 Logitech G Pro X Superlight Battery Replacement, Prepare your mouse for disassembly: 步骤 1 中的图像 2,3 Logitech G Pro X Superlight Battery Replacement, Prepare your mouse for disassembly: 步骤 1 中的图像 3,3
    • Slide your mouse's power switch down so it's in the OFF position.
    • A red indicator should be visible beneath the switch.
    • Unplug all cables from your mouse.
    • Flip the mouse over so the feet are facing up.
    • Throughout your repair, it may be helpful to lay your mouse on a soft cloth to stabilize it and prevent damage while you work.
  2. Logitech G Pro X Superlight Battery Replacement, Remove the feet: 步骤 2 中的图像 1,1
    • The feet are secured to the bottom of the mouse with strong adhesive. In order to cleanly remove them, the adhesive needs to be thoroughly heated.
    • Heat an iOpener and lay it on the mouse feet for one minute to heat the adhesive.
    • Alternatively, you can use a hair dryer on the Low heat setting to soften the adhesive.
    • If you're using a hair dryer, only heat the feet a few seconds at a time or you may warp the plastic shell.
  3. Logitech G Pro X Superlight Battery Replacement: 步骤 3 中的图像 1,3 Logitech G Pro X Superlight Battery Replacement: 步骤 3 中的图像 2,3 Logitech G Pro X Superlight Battery Replacement: 步骤 3 中的图像 3,3
    • The feet have two layers—a rubberized one and an adhesive pad underneath.
    • If you're reusing the feet, be very careful not to separate the two layers or damage the feet.
    • Carefully slide the point of a spudger under the circular foot, making sure it goes under both the foot and its adhesive pad.
    • The foot recesses have a small notch that makes it easier to slide your spudger under.
    • Gently slide the spudger farther under the foot and lift until you can grab it with your fingers.
  4. Logitech G Pro X Superlight Battery Replacement: 步骤 4 中的图像 1,2 Logitech G Pro X Superlight Battery Replacement: 步骤 4 中的图像 2,2
    • Peel up and remove the foot.
    • If the rubber layer separated from its adhesive pad, use the same process to remove the pad.
  5. Logitech G Pro X Superlight Battery Replacement: 步骤 5 中的图像 1,1
  6. Logitech G Pro X Superlight Battery Replacement, Reassembly information: 步骤 6 中的图像 1,3 Logitech G Pro X Superlight Battery Replacement, Reassembly information: 步骤 6 中的图像 2,3 Logitech G Pro X Superlight Battery Replacement, Reassembly information: 步骤 6 中的图像 3,3
    • To install a new foot:
    • If any of the feet got damaged during removal or separated from their adhesive pads, replace them.
    • Use a spudger to carefully scrape up and remove any remaining adhesive bits.
    • Use isopropyl alcohol and a microfiber cloth to thoroughly clean all adhesive residue from the foot recesses. Allow the surface to completely dry.
    • Remove the feet from their backing and firmly press them into place.
  7. Logitech G Pro X Superlight Battery Replacement, Separate the shells: 步骤 7 中的图像 1,2 Logitech G Pro X Superlight Battery Replacement, Separate the shells: 步骤 7 中的图像 2,2
    • Use a Phillips screwdriver to remove the six 4.5 mm‑long screws securing the bottom shell.
  8. Logitech G Pro X Superlight Battery Replacement: 步骤 8 中的图像 1,3 Logitech G Pro X Superlight Battery Replacement: 步骤 8 中的图像 2,3 Logitech G Pro X Superlight Battery Replacement: 步骤 8 中的图像 3,3
    • Don't try to fully separate the shells yet, as two cables still connect them.
    • Gently pull the top and bottom shells apart.
  9. Logitech G Pro X Superlight Battery Replacement: 步骤 9 中的图像 1,3 Logitech G Pro X Superlight Battery Replacement: 步骤 9 中的图像 2,3 Logitech G Pro X Superlight Battery Replacement: 步骤 9 中的图像 3,3
    • Set your mouse down with the bottom shell on the workspace and the top shell flipped over the right edge.
    • Use an object such as a small box or stack of books to prop up the top shell so you can access the cables without straining them.
  10. Logitech G Pro X Superlight Battery Replacement, Disconnect the shell cables: 步骤 10 中的图像 1,3 Logitech G Pro X Superlight Battery Replacement, Disconnect the shell cables: 步骤 10 中的图像 2,3 Logitech G Pro X Superlight Battery Replacement, Disconnect the shell cables: 步骤 10 中的图像 3,3
    • Use the point of a spudger to lift the locking flap on the top shell ZIF connector.
    • Use tweezers to gently pull the cable straight out of its socket.
    • During reassembly, insert the cable into its socket up to the white line before flipping down the locking flap.
  11. Logitech G Pro X Superlight Battery Replacement: 步骤 11 中的图像 1,3 Logitech G Pro X Superlight Battery Replacement: 步骤 11 中的图像 2,3 Logitech G Pro X Superlight Battery Replacement: 步骤 11 中的图像 3,3
    • Flip the top shell onto the mouse and let it rest so it's partially hanging over the left side, giving you access to the battery connector on the right edge.
  12. Logitech G Pro X Superlight Battery Replacement: 步骤 12 中的图像 1,3 Logitech G Pro X Superlight Battery Replacement: 步骤 12 中的图像 2,3 Logitech G Pro X Superlight Battery Replacement: 步骤 12 中的图像 3,3
    • Insert each arm of a pair of angled tweezers into the top of the cutouts on the right edge of the battery connector—the tweezers should curve upward.
    • Gently press the tweezers in and up to push the connector out of its socket enough that you can get a firm grip with your tweezers.
    • You may need to repeat this multiple times before the connector starts to come out.
  13. Logitech G Pro X Superlight Battery Replacement: 步骤 13 中的图像 1,1
    • Use tweezers to grip the battery connector and pull it straight up and out of its socket.
    • During reassembly, push down on the edges of the connector with the flat end of a spudger until it's fully seated in the socket.
  14. Logitech G Pro X Superlight Battery Replacement, The shells are separated: 步骤 14 中的图像 1,1
    • Remove the top shell from the bottom shell.
  15. Logitech G Pro X Superlight Battery Replacement, Remove the battery: 步骤 15 中的图像 1,2 Logitech G Pro X Superlight Battery Replacement, Remove the battery: 步骤 15 中的图像 2,2
    • The battery is secured to the top shell with mild adhesive. Heating the adhesive will soften it and make it easier to separate.
    • Use an iOpener or hair dryer to heat the battery.
    • If you're using a hair dryer, remember to have it on the Low setting and only apply heat a few seconds at a time.
  16. Logitech G Pro X Superlight Battery Replacement: 步骤 16 中的图像 1,3 Logitech G Pro X Superlight Battery Replacement: 步骤 16 中的图像 2,3 Logitech G Pro X Superlight Battery Replacement: 步骤 16 中的图像 3,3
    • Be very careful not to puncture or crease the battery during this step, as it can leak chemicals or catch fire.
    • With one hand, firmly secure the top shell.
    • With your free hand, insert the flat end of a spudger between the top edge of the battery and the shell.
    • Carefully slide the spudger under the battery and pry it up to separate the adhesive.
  17. Logitech G Pro X Superlight Battery Replacement: 步骤 17 中的图像 1,1
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $2.99
    • Remove the battery.
    • During reassembly:
    • Never install a deformed or damaged battery, as doing so is a potential safety hazard. Replace it with a new battery.
    • If the battery adhesive is still sticky, you can reuse it. Otherwise, remove all the old battery adhesive.
    • If your new battery has adhesive pre-installed, remove the plastic liner to expose the adhesive. Otherwise, apply strips of thin, double-sided tape to the battery well (not directly to the battery) where the old adhesive was.
    • Make sure the cable is on the side nearest its connector and firmly press the battery into place.
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
2等其他人完成本指南。
Spencer Day
于09/14/22注册
148,852 声望
创作了995篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,580篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 41
过去 7 天: 342
过去 30 天: 1,379
总计 14,572
