跳转到主内容
加入维修社区 - 创建账户
Logic Board Assembly Removal
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Logic Board Assembly Removal, Prepare your Mac Studio for disassembly: 步骤 1 中的图像 1,3 Logic Board Assembly Removal, Prepare your Mac Studio for disassembly: 步骤 1 中的图像 2,3 Logic Board Assembly Removal, Prepare your Mac Studio for disassembly: 步骤 1 中的图像 3,3
    • Completely shut down your Mac Studio.
    • Unplug all cables from your device.
  2. Logic Board Assembly Removal, Flip your Mac Studio over: 步骤 2 中的图像 1,1
    • Flip your Mac Studio over and lay it down so the bottom faces up and the SD card slot and two front USB‑C ports are facing you.
  3. Logic Board Assembly Removal, Heat the bottom cover screw pad: 步骤 3 中的图像 1,3 Logic Board Assembly Removal, Heat the bottom cover screw pad: 步骤 3 中的图像 2,3 Logic Board Assembly Removal, Heat the bottom cover screw pad: 步骤 3 中的图像 3,3
    • Adhesive strips secure the bottom cover screw pad.
    • Heat an iOpener and lay it over one of the bottom cover screws for two minutes to soften the adhesive near the screw—this is where you'll insert a spudger in the next step.
    • You can also use a hair dryer or heat gun, but be careful as extreme heat will warp the pad.
  4. Logic Board Assembly Removal, Lift a section of bottom cover screw pad: 步骤 4 中的图像 1,3 Logic Board Assembly Removal, Lift a section of bottom cover screw pad: 步骤 4 中的图像 2,3 Logic Board Assembly Removal, Lift a section of bottom cover screw pad: 步骤 4 中的图像 3,3
    • Insert the point of a spudger under the pad's inner edge, near the screw you applied heat to in the previous step.
    • This may take some force. If you're having trouble, apply more heat and try again.
    • Use the spudger to lift the pad and separate the adhesive.
  5. Logic Board Assembly Removal, Separate the remaining adhesive: 步骤 5 中的图像 1,3 Logic Board Assembly Removal, Separate the remaining adhesive: 步骤 5 中的图像 2,3 Logic Board Assembly Removal, Separate the remaining adhesive: 步骤 5 中的图像 3,3
    • Insert the flat end of a spudger under the pad.
    • Slide the spudger under the entire pad to separate the remaining adhesive.
  6. Logic Board Assembly Removal, Remove the bottom cover screw pad: 步骤 6 中的图像 1,1
    • Remove the bottom cover screw pad.
  7. Logic Board Assembly Removal, Reassembly information: 步骤 7 中的图像 1,3 Logic Board Assembly Removal, Reassembly information: 步骤 7 中的图像 2,3 Logic Board Assembly Removal, Reassembly information: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $2.99
    • During reassembly:
    • If the adhesive strips are still sticky, you can reuse them.
    • If you're applying new adhesive:
    • Use the flat end of a spudger and your fingers to scrape up and remove the old adhesive strips.
    • Use isopropyl alcohol and a microfiber cloth to remove the old adhesive residue.
    • If you don't have replacement adhesive, you can use strips of thin, double-sided tape 2–3 mm wide.
    • Apply the new adhesive strips to the bottom cover and remove their liners.
    • Firmly press the bottom cover screw pad into its recess to secure it.
  8. Logic Board Assembly Removal, Remove the bottom cover screws: 步骤 8 中的图像 1,2 Logic Board Assembly Removal, Remove the bottom cover screws: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    FixMat
    $36.95
    • While the Mac Studio uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a T10 Torx screwdriver to remove the four 8 mm‑long screws securing the bottom cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came.
  9. Logic Board Assembly Removal, Remove the bottom cover: 步骤 9 中的图像 1,3 Logic Board Assembly Removal, Remove the bottom cover: 步骤 9 中的图像 2,3 Logic Board Assembly Removal, Remove the bottom cover: 步骤 9 中的图像 3,3
    • Insert the point of a spudger in one of the bottom cover's ventilation holes and lift the cover until you can grab it with your fingers.
    • Remove the bottom cover.
    • To orient the bottom cover, align the Kensington lock cutout in the top left corner with the corresponding one on the internal frame.
  10. Logic Board Assembly Removal, Remove the power supply screws: 步骤 10 中的图像 1,2 Logic Board Assembly Removal, Remove the power supply screws: 步骤 10 中的图像 2,2
    • Use a T10 Torx screwdriver to remove the six screws securing the power supply:
    • Four 6 mm‑long screws
    • Two 7 mm‑long screws with washers
    • You may need to remove a sticker to access these screws. If you do, save it for reassembly.
  11. Logic Board Assembly Removal, Reposition your Mac Studio: 步骤 11 中的图像 1,1
    • Flip your Mac Studio around so the rear ports are facing you.
  12. Logic Board Assembly Removal, Disconnect the power cord port cable: 步骤 12 中的图像 1,3 Logic Board Assembly Removal, Disconnect the power cord port cable: 步骤 12 中的图像 2,3 Logic Board Assembly Removal, Disconnect the power cord port cable: 步骤 12 中的图像 3,3
    • A tight plastic latch secures the power cord port cable.
    • Firmly hold the power supply with one hand and lift up the edge near the power cord port.
    • With your free hand, pinch the head of the power cord port connector to unclip it and pull straight down to disconnect the cable.
  13. Logic Board Assembly Removal, Tilt up the power supply: 步骤 13 中的图像 1,1
    • Only grab the power supply by its edges. Various power components and capacitors are left exposed.
    • Carefully tilt the power supply away from the power cord port so it's at a 90-degree angle.
    • Be careful not to strain the cable that's still connected to the power supply.
    • Keep the power supply tilted up for the next step.
  14. Logic Board Assembly Removal, Disconnect the power supply signal cable: 步骤 14 中的图像 1,3 Logic Board Assembly Removal, Disconnect the power supply signal cable: 步骤 14 中的图像 2,3 Logic Board Assembly Removal, Disconnect the power supply signal cable: 步骤 14 中的图像 3,3
    • A delicate plastic clip secures the power supply signal cable.
    • With your free hand, pinch the head of the power supply connector to unclip it and pull straight away from the socket to disconnect the cable.
  15. Logic Board Assembly Removal, Remove the power supply: 步骤 15 中的图像 1,1
    • Remove the power supply.
  16. Logic Board Assembly Removal, Reposition your Mac Studio: 步骤 16 中的图像 1,1
    • Flip your Mac Studio around so the SD card reader and two front USB‑C ports are facing you.
  17. Logic Board Assembly Removal, Remove the internal frame screws: 步骤 17 中的图像 1,2 Logic Board Assembly Removal, Remove the internal frame screws: 步骤 17 中的图像 2,2
    • Use a T6 Torx screwdriver to remove the eight screws securing the internal frame:
    • Seven 5 mm‑long screws
    • One 4 mm‑long screw
  18. Logic Board Assembly Removal, Remove the internal frame: 步骤 18 中的图像 1,2 Logic Board Assembly Removal, Remove the internal frame: 步骤 18 中的图像 2,2
  19. Logic Board Assembly Removal, Remove the antenna cable cover: 步骤 19 中的图像 1,3 Logic Board Assembly Removal, Remove the antenna cable cover: 步骤 19 中的图像 2,3 Logic Board Assembly Removal, Remove the antenna cable cover: 步骤 19 中的图像 3,3
    • Use a T3 Torx screwdriver to remove the two 2 mm‑long screws securing the antenna cable cover.
    • Use tweezers or your fingers to remove the cover.
  20. Logic Board Assembly Removal, Disconnect antenna 2: 步骤 20 中的图像 1,2 Logic Board Assembly Removal, Disconnect antenna 2: 步骤 20 中的图像 2,2
    • Insert one arm of a pair of angled tweezers under the metal neck of antenna 2's coaxial connector and lift straight up to disconnect it.
    • To reconnect the cable, hold the connector in place over its socket and press down with the flat end of a spudger—the connector should snap into place. If you're having trouble, don't try to force the connector over the socket. Reposition it and try again.
  21. Logic Board Assembly Removal, Remove antenna 2's screws: 步骤 21 中的图像 1,2 Logic Board Assembly Removal, Remove antenna 2's screws: 步骤 21 中的图像 2,2
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing antenna 2.
  22. Logic Board Assembly Removal, Remove antenna 2: 步骤 22 中的图像 1,2 Logic Board Assembly Removal, Remove antenna 2: 步骤 22 中的图像 2,2
    • Remove antenna 2.
  23. Logic Board Assembly Removal, Disconnect antenna 3: 步骤 23 中的图像 1,3 Logic Board Assembly Removal, Disconnect antenna 3: 步骤 23 中的图像 2,3 Logic Board Assembly Removal, Disconnect antenna 3: 步骤 23 中的图像 3,3
    • Insert one arm of a pair of angled tweezers under the metal neck of antenna 3's coaxial connector (next to antenna 2's connector) and lift straight up to disconnect it.
  24. Logic Board Assembly Removal, Unclip the cable: 步骤 24 中的图像 1,3 Logic Board Assembly Removal, Unclip the cable: 步骤 24 中的图像 2,3 Logic Board Assembly Removal, Unclip the cable: 步骤 24 中的图像 3,3
  25. Logic Board Assembly Removal, Remove antenna 3's screws: 步骤 25 中的图像 1,2 Logic Board Assembly Removal, Remove antenna 3's screws: 步骤 25 中的图像 2,2
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing antenna 3.
  26. Logic Board Assembly Removal, Remove antenna 3: 步骤 26 中的图像 1,2 Logic Board Assembly Removal, Remove antenna 3: 步骤 26 中的图像 2,2
    • Remove antenna 3.
  27. Logic Board Assembly Removal, Remove the ethernet board cable cover: 步骤 27 中的图像 1,3 Logic Board Assembly Removal, Remove the ethernet board cable cover: 步骤 27 中的图像 2,3 Logic Board Assembly Removal, Remove the ethernet board cable cover: 步骤 27 中的图像 3,3
    • Use a T3 Torx screwdriver to remove the two 2 mm‑long screws securing the ethernet board cable cover.
  28. Logic Board Assembly Removal, Disconnect the ethernet board: 步骤 28 中的图像 1,2 Logic Board Assembly Removal, Disconnect the ethernet board: 步骤 28 中的图像 2,2
    • Be very careful not to scrape off or damage any surface mounted components during this step.
    • Use a spudger to pry up and disconnect the ethernet board cable press connector from the logic board.
    • To reconnect press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  29. Logic Board Assembly Removal, Reposition your Mac Studio: 步骤 29 中的图像 1,1
    • Carefully stand up your Mac Studio so the SD card reader and two front USB-C ports are facing up.
  30. Logic Board Assembly Removal, Remove the ethernet board cable: 步骤 30 中的图像 1,3 Logic Board Assembly Removal, Remove the ethernet board cable: 步骤 30 中的图像 2,3 Logic Board Assembly Removal, Remove the ethernet board cable: 步骤 30 中的图像 3,3
    在这个步骤中使用的工具:
    Flexible Extension
    $6.99
    • Use a T4 Torx screwdriver to remove the two 11 mm‑long screws securing the right side of the ethernet board and its cover.
    • These screws may be hard to access. If you can't insert your screwdriver properly, use a flexible extension to avoid stripping screws or damaging the logic board.
  31. Logic Board Assembly Removal: 步骤 31 中的图像 1,3 Logic Board Assembly Removal: 步骤 31 中的图像 2,3 Logic Board Assembly Removal: 步骤 31 中的图像 3,3
    • Insert the point of a spudger under the bottom right corner of the ethernet board press connector and lift up to disconnect it.
    • Don't pry against any surface mounted components.
    • Remove the cable.
  32. Logic Board Assembly Removal, Remove the ethernet board screws: 步骤 32 中的图像 1,2 Logic Board Assembly Removal, Remove the ethernet board screws: 步骤 32 中的图像 2,2
    在这个步骤中使用的工具:
    Flexible Extension
    $6.99
    • Use a T6 Torx screwdriver to remove the two 20 mm‑long screws (with washers) securing the ethernet board.
    • Be careful not to lose the washers, as they can fall off easily.
  33. Logic Board Assembly Removal, Remove the ethernet board: 步骤 33 中的图像 1,2 Logic Board Assembly Removal, Remove the ethernet board: 步骤 33 中的图像 2,2
    • Lift the ethernet board out of its recess and remove it.
  34. Logic Board Assembly Removal, Reposition your Mac Studio: 步骤 34 中的图像 1,1
    • Reposition your Mac Studio so the SD card reader and two front USB‑C ports are facing you.
  35. Logic Board Assembly Removal, Remove the speaker screws: 步骤 35 中的图像 1,3 Logic Board Assembly Removal, Remove the speaker screws: 步骤 35 中的图像 2,3 Logic Board Assembly Removal, Remove the speaker screws: 步骤 35 中的图像 3,3
    • Use a T5 Torx screwdriver to remove the two 12 mm‑long screws securing the speaker.
  36. Logic Board Assembly Removal, Reposition the speaker: 步骤 36 中的图像 1,3 Logic Board Assembly Removal, Reposition the speaker: 步骤 36 中的图像 2,3 Logic Board Assembly Removal, Reposition the speaker: 步骤 36 中的图像 3,3
  37. Logic Board Assembly Removal, Disconnect the speaker: 步骤 37 中的图像 1,2 Logic Board Assembly Removal, Disconnect the speaker: 步骤 37 中的图像 2,2
    • Insert the point of a spudger under the speaker connector's plastic head and carefully lift it straight up and out of its socket.
    • Don't lift on the wires themselves, or you may damage them.
    • To reconnect the cable, position the connector head over its socket and press to with the flat end of a spudger—the connector should click into place.
  38. Logic Board Assembly Removal, Remove the speaker: 步骤 38 中的图像 1,1
    • Remove the speaker.
  39. Logic Board Assembly Removal, Remove the cable cover screws: 步骤 39 中的图像 1,2 Logic Board Assembly Removal, Remove the cable cover screws: 步骤 39 中的图像 2,2
    • Use a T3 Torx screwdriver to remove the two 2 mm‑long screws securing the I/O board cable cover.
    • Use a T8 Torx screwdriver to remove the standoff screw just to the right of the cover.
  40. Logic Board Assembly Removal, Remove the cover: 步骤 40 中的图像 1,1
    • Use tweezers or your fingers to remove the I/O board cable cover.
  41. Logic Board Assembly Removal, Disconnect the I/O board: 步骤 41 中的图像 1,3 Logic Board Assembly Removal, Disconnect the I/O board: 步骤 41 中的图像 2,3 Logic Board Assembly Removal, Disconnect the I/O board: 步骤 41 中的图像 3,3
    • Use a spudger to pry up and disconnect both of the I/O board's press connectors.
  42. Logic Board Assembly Removal, Disconnect the power button: 步骤 42 中的图像 1,3 Logic Board Assembly Removal, Disconnect the power button: 步骤 42 中的图像 2,3 Logic Board Assembly Removal, Disconnect the power button: 步骤 42 中的图像 3,3
    • Use the point of a spudger or a clean fingernail to flip up the hinged locking flap on the power button cable ZIF connector, located on the outer edge of the I/O board.
    • Use tweezers to gently pull the cable straight out of its socket.
  43. Logic Board Assembly Removal, Reposition your Mac Studio: 步骤 43 中的图像 1,1
  44. Logic Board Assembly Removal, Remove the I/O board screws: 步骤 44 中的图像 1,3 Logic Board Assembly Removal, Remove the I/O board screws: 步骤 44 中的图像 2,3 Logic Board Assembly Removal, Remove the I/O board screws: 步骤 44 中的图像 3,3
    在这个步骤中使用的工具:
    Flexible Extension
    $6.99
    • Use a T4 Torx screwdriver to remove the two 15.5 mm‑long screws securing the outer edge of the I/O board.
    • Use a T6 Torx screwdriver to remove the two 20 mm‑long screws securing the inner edge of the I/O board.
    • Partially tighten the four screws securing the board.
    • Lay your Mac Studio down and plug a cable into one of the ports to ensure proper fit and alignment, adjusting the port as necessary—the cable should be easy to insert and remove.
    • With the cable plugged in and the board in position, fully tighten all four screws.
    • Unplug all cables before continuing.
  45. Logic Board Assembly Removal, Remove the I/O board: 步骤 45 中的图像 1,3 Logic Board Assembly Removal, Remove the I/O board: 步骤 45 中的图像 2,3 Logic Board Assembly Removal, Remove the I/O board: 步骤 45 中的图像 3,3
    • Lift the I/O board straight up and out of its recess to remove it.
    • During reassembly, lower the board into its recess, making sure the press connectors don't get trapped under the logic board.
  46. Logic Board Assembly Removal, Remove the power cord port: 步骤 46 中的图像 1,2 Logic Board Assembly Removal, Remove the power cord port: 步骤 46 中的图像 2,2
    • Lift the power cord port out of its recess and remove it.
  47. Logic Board Assembly Removal, Reposition your Mac Studio: 步骤 47 中的图像 1,1
  48. Logic Board Assembly Removal, Remove the USB‑C bracket: 步骤 48 中的图像 1,3 Logic Board Assembly Removal, Remove the USB‑C bracket: 步骤 48 中的图像 2,3 Logic Board Assembly Removal, Remove the USB‑C bracket: 步骤 48 中的图像 3,3
    在这个步骤中使用的工具:
    Flexible Extension
    $6.99
  49. Logic Board Assembly Removal, Remove the cable cover: 步骤 49 中的图像 1,3 Logic Board Assembly Removal, Remove the cable cover: 步骤 49 中的图像 2,3 Logic Board Assembly Removal, Remove the cable cover: 步骤 49 中的图像 3,3
    • Use a T3 Torx screwdriver to remove the two 2 mm‑long screws securing the USB‑C port cable cover.
  50. Logic Board Assembly Removal, Disconnect the USB-C ports: 步骤 50 中的图像 1,2 Logic Board Assembly Removal, Disconnect the USB-C ports: 步骤 50 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the USB‑C port press connector from the logic board.
    • To reconnect press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  51. Logic Board Assembly Removal, Reposition your Mac Studio: 步骤 51 中的图像 1,1
    • Carefully stand up your Mac Studio so the rear ports face up.
  52. Logic Board Assembly Removal, Remove the USB-C ports screws: 步骤 52 中的图像 1,3 Logic Board Assembly Removal, Remove the USB-C ports screws: 步骤 52 中的图像 2,3 Logic Board Assembly Removal, Remove the USB-C ports screws: 步骤 52 中的图像 3,3
    在这个步骤中使用的工具:
    Flexible Extension
    $6.99
    • Use a T5 Torx screwdriver to remove the two 5 mm‑long screws securing the USB-C ports.
    • Partially tighten the two screws securing the top of the ports.
    • Put the USB-C bracket into place and partially tighten the screw that secures it.
    • Lay your Mac Studio down and plug a cable into each port to ensure proper fit and alignment, adjusting the ports as necessary—the cables should be easy to insert and remove.
    • With both cables plugged in and the ports in position, fully tighten all three screws.
    • Unplug any cables before continuing reassembly.
  53. Logic Board Assembly Removal, Remove the USB-C ports: 步骤 53 中的图像 1,3 Logic Board Assembly Removal, Remove the USB-C ports: 步骤 53 中的图像 2,3 Logic Board Assembly Removal, Remove the USB-C ports: 步骤 53 中的图像 3,3
    • Use your fingers to lift the ports out of their recesses and remove them.
    • Don't try to remove an individual port. A flex cable connects them and can easily be damaged.
    • During reassembly, put the ports into their recesses, making sure the press connector stays above the logic board.
  54. Logic Board Assembly Removal, Reposition your Mac Studio: 步骤 54 中的图像 1,1
  55. Logic Board Assembly Removal, Remove the cable cover: 步骤 55 中的图像 1,3 Logic Board Assembly Removal, Remove the cable cover: 步骤 55 中的图像 2,3 Logic Board Assembly Removal, Remove the cable cover: 步骤 55 中的图像 3,3
    • Use a T3 Torx screwdriver to remove the two 2 mm‑long screws securing the back Thunderbolt 4 port cable cover.
  56. Logic Board Assembly Removal, Disconnect the ports: 步骤 56 中的图像 1,3 Logic Board Assembly Removal, Disconnect the ports: 步骤 56 中的图像 2,3 Logic Board Assembly Removal, Disconnect the ports: 步骤 56 中的图像 3,3
    • Use a spudger to pry up and disconnect both Thunderbolt 4 cable press connectors from the logic board.
  57. Logic Board Assembly Removal, Reposition your Mac Studio: 步骤 57 中的图像 1,1
    • Carefully stand up your Mac Studio so the SD card reader and front two USB-C ports face up.
  58. Logic Board Assembly Removal, Remove the ports screws: 步骤 58 中的图像 1,3 Logic Board Assembly Removal, Remove the ports screws: 步骤 58 中的图像 2,3 Logic Board Assembly Removal, Remove the ports screws: 步骤 58 中的图像 3,3
    在这个步骤中使用的工具:
    Flexible Extension
    $6.99
    • Use a T5 Torx screwdriver to remove the six 5 mm‑long screws securing three of the ports.
    • Use a T7 Torx screwdriver to remove the two 8 mm‑long standoff screws securing the remaining port.
    • To align and install a set of ports during reassembly:
    • Partially tighten all four screws on a set of ports.
    • Lay your Mac Studio down and plug a cable into each port to ensure proper fit and alignment, adjusting the ports as necessary—the cable should be easy to insert and remove.
    • With both cables plugged in and the port in position, fully tighten the screws.
    • Unplug all cables before continuing with reassembly.
  59. Logic Board Assembly Removal, Remove the ports: 步骤 59 中的图像 1,3 Logic Board Assembly Removal, Remove the ports: 步骤 59 中的图像 2,3 Logic Board Assembly Removal, Remove the ports: 步骤 59 中的图像 3,3
    • Flex cables connect the two inner and two outer port pairs. Don't try to remove individual ports—you can easily damage the cables that connect them.
    • Use your fingers to lift the two inner or outer ports out of their recesses and remove them.
    • Repeat the process to remove the two other ports.
    • During reassembly, put the ports into their recesses, making sure the press connectors stay above the logic board.
  60. Logic Board Assembly Removal, Reposition your Mac Studio: 步骤 60 中的图像 1,1
    • Reposition your Mac Studio so the power cord port is facing you.
  61. Logic Board Assembly Removal, Remove the cable cover screws: 步骤 61 中的图像 1,3 Logic Board Assembly Removal, Remove the cable cover screws: 步骤 61 中的图像 2,3 Logic Board Assembly Removal, Remove the cable cover screws: 步骤 61 中的图像 3,3
    • Use a T3 Torx screwdriver to remove the four 2 mm‑long screws securing the SDXC card reader cable covers.
  62. Logic Board Assembly Removal, Remove the cable covers: 步骤 62 中的图像 1,3 Logic Board Assembly Removal, Remove the cable covers: 步骤 62 中的图像 2,3 Logic Board Assembly Removal, Remove the cable covers: 步骤 62 中的图像 3,3
    • Use tweezers or your fingers to remove the two cable covers.
  63. Logic Board Assembly Removal, Remove the cable: 步骤 63 中的图像 1,3 Logic Board Assembly Removal, Remove the cable: 步骤 63 中的图像 2,3 Logic Board Assembly Removal, Remove the cable: 步骤 63 中的图像 3,3
    • Use the flat end of a spudger to pry up and disconnect the card reader cable press connector from the logic board.
    • Use the point of a spudger to disconnect the cable's other press connector from the reader itself.
    • Remove the cable.
  64. Logic Board Assembly Removal, Disconnect the card reader: 步骤 64 中的图像 1,3 Logic Board Assembly Removal, Disconnect the card reader: 步骤 64 中的图像 2,3 Logic Board Assembly Removal, Disconnect the card reader: 步骤 64 中的图像 3,3
    • Use the point of a spudger or a clean fingernail to flip up the hinged locking flap on the status indicator light cable ZIF connector, located on the right side of the card reader.
  65. Logic Board Assembly Removal: 步骤 65 中的图像 1,2 Logic Board Assembly Removal: 步骤 65 中的图像 2,2
    • Very light adhesive secures the cable to the side of the card reader.
    • Use tweezers to gently pull the cable away from the card reader and separate the adhesive.
  66. Logic Board Assembly Removal, Reposition your Mac Studio: 步骤 66 中的图像 1,1
  67. Logic Board Assembly Removal, Remove the SDXC card reader screws: 步骤 67 中的图像 1,2 Logic Board Assembly Removal, Remove the SDXC card reader screws: 步骤 67 中的图像 2,2
    在这个步骤中使用的工具:
    Flexible Extension
    $6.99
    • Use a T5 Torx screwdriver to remove the two 6 mm‑long screws securing the card reader.
  68. Logic Board Assembly Removal, Remove the card reader: 步骤 68 中的图像 1,2 Logic Board Assembly Removal, Remove the card reader: 步骤 68 中的图像 2,2
    • Remove the card reader.
  69. Logic Board Assembly Removal, Reposition your Mac Studio: 步骤 69 中的图像 1,1
  70. Logic Board Assembly Removal, Remove antenna 1's screws: 步骤 70 中的图像 1,2 Logic Board Assembly Removal, Remove antenna 1's screws: 步骤 70 中的图像 2,2
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing antenna 1.
  71. Logic Board Assembly Removal, Secure antenna 1: 步骤 71 中的图像 1,3 Logic Board Assembly Removal, Secure antenna 1: 步骤 71 中的图像 2,3 Logic Board Assembly Removal, Secure antenna 1: 步骤 71 中的图像 3,3
    • Gently lay antenna 1 to the left of the heatsink, being careful not to strain its cable.
    • Secure antenna 1 to the logic board with a strip of painters tape.
    • Stick the tape to the heatsink screws, not directly onto the board.
  72. Logic Board Assembly Removal, Remove the logic board assembly screws: 步骤 72 中的图像 1,2 Logic Board Assembly Removal, Remove the logic board assembly screws: 步骤 72 中的图像 2,2
    • Use a T20 Torx screwdriver to remove the four 12 mm‑long screws securing the logic board assembly.
  73. Logic Board Assembly Removal, Remove the logic board assembly: 步骤 73 中的图像 1,3 Logic Board Assembly Removal, Remove the logic board assembly: 步骤 73 中的图像 2,3 Logic Board Assembly Removal, Remove the logic board assembly: 步骤 73 中的图像 3,3
    • Before trying to remove the logic board assembly, note the following:
    • The assembly sits very snugly in its housing. Take your time and don't try to force it out.
    • Only grip the assembly by areas on the logic board that don't have any components. Otherwise, you may damage the board.
    • Firmly secure the housing with one hand.
    • With your free hand, carefully lift the edge of the logic board assembly with the SSD modules until you can grip the fans. Slide the assembly towards the power cord cutout as necessary to help you lift it higher.
    • Grip the board and fans together and lift the assembly out of its housing.
    • Be careful not to damage any components on the edge of the assembly when removing it.
    • During reassembly, lower the logic board assembly into its housing at a downward angle so the side with a rubber gasket is facing the power cord cutout.
结论
Spencer Day
于09/14/22注册
161,523 声望
创作了1,045篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了24,048篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 51
