跳转到主内容
加入维修社区 - 创建账户
LexiBook Tablet One Speaker Replacement
你所需要的
    1. LexiBook Tablet One Speaker Replacement, Speaker: 步骤 1 中的图像 1,3 LexiBook Tablet One Speaker Replacement, Speaker: 步骤 1 中的图像 2,3 LexiBook Tablet One Speaker Replacement, Speaker: 步骤 1 中的图像 3,3
      • Insert the blue plastic opening tool where the case has a seam. Move side to side until you hear a clip pop. Move around the edge of the case until all clips are separated. The clips are 1.5 in. apart within the case.
      询问修复机器人
      添加评论
    2. LexiBook Tablet One Speaker Replacement: 步骤 2 中的图像 1,2 LexiBook Tablet One Speaker Replacement: 步骤 2 中的图像 2,2
      • After successfully separating the casing insert a plastic spudger between the case and the speaker. Carefully pry the speaker out. Once the speaker is removed set the back casing aside.
      询问修复机器人
      添加评论
    3. LexiBook Tablet One Speaker Replacement: 步骤 3 中的图像 1,1
      • Using a soldering gun, apply heat where the speaker wires meet the motherboard. Heat the solder around both the black and red wires until they easily slide away.
      • Be careful not to heat the motherboard too long so to avoid damaging other components. Also, care to avoid liquefying the solder on any near by components.
      • How to Solder is IFixIt's official guide to use a soldering gun.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
Jordan
于03/11/15注册
650 声望
创作了4篇指南
团队
Colorado Springs, Team 2-5, Panko Spring 2015 Colorado Springs, Team 2-5, Panko Spring 2015 的会员
UCCS-PANKO-S15S2G5
3 名成员
创作了30篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 31
总计 434
