跳转到主内容
Lenovo Yoga C930-13IKB Wi-Fi Card Replacement
Jessie Boucher
Jessie Boucher3 其他贡献者
最后更新于 March 19, 2024
5分钟
简单
If you are having Wi-Fi problems and none of the solutions found on this troubleshooting page work, you may need to replace the physical Wi-Fi card in your Lenovo Yoga C930-13IKB. The only Wi-Fi card that is compatible with the Lenovo Yoga C930-13IKB is the Intel 9260 Wi-Fi card. Do not install a different Wi-Fi card.
Before buying a new card, check if all the wires are connected to the Wi-Fi card currently in your laptop. Poor physical connection to the motherboard or antenna will cause Wi-Fi problems.
你所需要的
配件
工具
查看更多...
  1. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Flip the device over so that the underside is facing up.
    • Remove the six 3.5 mm T5 Torx screws.
  2. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: 步骤 2 中的图像 1,2 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: 步骤 2 中的图像 2,2
    • Pry off the back cover using the plastic opening tool.
    • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
    • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
    • Do not use a metal tool when working with your device.
  3. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: 步骤 3 中的图像 1,2 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: 步骤 3 中的图像 2,2
    • Carefully lift the cover off with your hands.
  4. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement, Wi-Fi Card: 步骤 4 中的图像 1,2 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement, Wi-Fi Card: 步骤 4 中的图像 2,2
    • Find the Wi-Fi card located on the right just above the battery. It is a green chip with a white label that says "Intel 9260" somewhere on it.
  5. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: 步骤 5 中的图像 1,2 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: 步骤 5 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the single 2 mm screw that attaches the card to the motherboard.
  6. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: 步骤 6 中的图像 1,3 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: 步骤 6 中的图像 2,3 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    iFixit Opening Tool
    $1.99
    • Gently pull or use the iFixit opening tool to detach the black and white wires from the card.
    • When reassembling, these wires are difficult to reattach, so be patient. Line the wires up with your fingers and press down on the connections with the opening tool.
  7. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: 步骤 7 中的图像 1,2 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: 步骤 7 中的图像 2,2
    • Pinch the card on either side and pull to the right to unplug it from the motherboard.
结论
4等其他人完成本指南。
Jessie Boucher
于01/23/20注册
295 声望
撰写一个指南
团队
Cal Poly, Team S19-G5, White Winter 2020 Cal Poly, Team S19-G5, White Winter 2020 的会员
CPSU-WHITE-W20S19G5
4 名成员
创作了16篇指南
2条评论
Brilliant! very clear instructions and it fixed my fault. I wonder if this is a relatively common fault. Windows unable to find WiFi adapter.
Thank you for your efforts
David Pugh - 回复
Does anyone know if i need a Lenovo specific 9260 or does any Intel 9260 card work?
the ones sold as a "lenovo" version is 3x the price where i am, so i would like to avoid that if possible.
Einstein Teigland - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 14
总计 1,617
