跳转到主内容
Lenovo Yoga 900-13ISK Fan Assembly Replacement
你所需要的
  1. Lenovo Yoga 900-13ISK Fan Assembly Replacement, Back Cover: 步骤 1 中的图像 1,2 Lenovo Yoga 900-13ISK Fan Assembly Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Using a T5 Torx screwdriver, remove the ten 5.5 mm screws from the back case of the laptop.
  2. Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 2 中的图像 1,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 2 中的图像 2,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 2 中的图像 3,3
    • Use a spudger to pry open the back case at the hinges of the laptop.
    • There are plastic clips around the perimeter of the case holding down the back cover. These will need to be popped off as the cover is removed.
    • Use your fingers to completely pop off the back cover.
  3. Lenovo Yoga 900-13ISK Fan Assembly Replacement, Battery: 步骤 3 中的图像 1,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement, Battery: 步骤 3 中的图像 2,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement, Battery: 步骤 3 中的图像 3,3
    • Remove the five 3.6 mm screws from the battery with a Phillips #00 screwdriver.
  4. Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 4 中的图像 1,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 4 中的图像 2,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 4 中的图像 3,3
    • Grab the bottom corners of the battery and gently pull the battery until the cable disconnects from the connector on the motherboard.
    • While reassembling, use a plastic spudger to push the battery cable into the connector on the underside of the motherboard. This will be easier to do before the screws are replaced.
  5. Lenovo Yoga 900-13ISK Fan Assembly Replacement, Solid State Drive: 步骤 5 中的图像 1,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement, Solid State Drive: 步骤 5 中的图像 2,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement, Solid State Drive: 步骤 5 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the 2.7 mm screw that is holding down the SSD card.
  6. Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 6 中的图像 1,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 6 中的图像 2,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 6 中的图像 3,3
    • Pull the SSD card out of the port to the right.
  7. Lenovo Yoga 900-13ISK Fan Assembly Replacement, Wi-Fi Card Prereq: 步骤 7 中的图像 1,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement, Wi-Fi Card Prereq: 步骤 7 中的图像 2,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement, Wi-Fi Card Prereq: 步骤 7 中的图像 3,3
    • Pry up the gray and black coaxial cables from the Wi-Fi card using a spudger.
    • Move the cables to the side.
  8. Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 8 中的图像 1,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 8 中的图像 2,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 8 中的图像 3,3
    • Using a Phillips #00 screwdriver, remove the 2.2 mm screw holding down the Wi-Fi card.
    • The Wi-Fi card may pop up to rest at an angle to the motherboard after the screw is removed.
  9. Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 9 中的图像 1,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 9 中的图像 2,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 9 中的图像 3,3
    • Pull the WiFi card out from the connector on the motherboard.
  10. Lenovo Yoga 900-13ISK Fan Assembly Replacement, Motherboard: 步骤 10 中的图像 1,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement, Motherboard: 步骤 10 中的图像 2,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement, Motherboard: 步骤 10 中的图像 3,3
    • Using the pointed end of a spudger, flip up the hinged locking tabs of the eight ZIF connectors on the motherboard.
    • Pull the eight cables out from their connectors using a pair of blunt nose tweezers.
  11. Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 11 中的图像 1,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 11 中的图像 2,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 11 中的图像 3,3
  12. Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 12 中的图像 1,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 12 中的图像 2,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 12 中的图像 3,3
    • Remove the five 3.6 mm screws from the motherboard using a Phillips #00 screwdriver.
  13. Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 13 中的图像 1,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 13 中的图像 2,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 13 中的图像 3,3
    • Pull back the interconnect cable on the left side of the motherboard to reveal one of the fan screws for the left fan.
    • Remove the two 3.6 mm screws from the left fan with a Phillips #00 screwdriver.
  14. Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 14 中的图像 1,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 14 中的图像 2,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 14 中的图像 3,3
    • Remove the two 3.6 mm screws from the right fan using a Phillips #00 screwdriver.
  15. Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 15 中的图像 1,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 15 中的图像 2,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 15 中的图像 3,3
    • Unwind the black and white coaxial cables from the hooks on the right fan casing.
  16. Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 16 中的图像 1,2 Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 16 中的图像 2,2
    • Lift the motherboard from the bottom edge and pull it up and out of the case.
    • If you need to remove the fan assembly to swap it over to your new motherboard, continue to follow along with the heatsink guide.
  17. Lenovo Yoga 900-13ISK Fan Assembly Replacement, Fan Assembly: 步骤 17 中的图像 1,2 Lenovo Yoga 900-13ISK Fan Assembly Replacement, Fan Assembly: 步骤 17 中的图像 2,2
    • Flip the motherboard over to access the heatsink.
  18. Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 18 中的图像 1,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 18 中的图像 2,3 Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 18 中的图像 3,3
    • Unscrew the three captive screws on the heatsink with a Phillips #1 screwdriver.
    • These screws can be very tight, so be sure to employ screwdriver best practices and apply a lot of downward force to avoid stripping the screws.
  19. Lenovo Yoga 900-13ISK Fan Assembly Replacement: 步骤 19 中的图像 1,1
    • Lift the heatsink and fan assembly off of the motherboard.
    • Be sure to clean off the old thermal paste and replace it with a fresh application any time the heatsink is separated from the CPU. Check out our How to Apply Thermal Paste guide if you need help!
结论
Austin Blakely
于03/11/19注册
19,536 声望
创作了53篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了17,187篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 24
总计 1,435
